rear wiper wiring - JeepForum.com
post #1 of 4 Old 04-04-2010, 09:01 PM Thread Starter
Matt24138
rear wiper wiring
Is there a way to wire up the wiper in my hard top without buying a kit or the harness off of ebay for 100.00. I just bought a 93 someone added a hard top too. with no wiring any help is greatlp appreciated.
Thanks,
Matt
Matt24138 is offline
post #2 of 4 Old 04-06-2010, 07:55 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Thanks,
Matt
Do you have a plug at the left rear corner of the tub? It has two rows of 5 pin slots and is rounded one two corners and are square on the other two corners. From the top left round corner (that is pin #1). Pin #4 &#5 each have a wire in it. That is for the wiper cirrcuit. A wire in pin #7 would be for the washer circuit.
That is not from a 91 YJ wiring diagram but they probsblky did not change much from year to year. See if there is a small hose there also. That would be your window washer hose. If it is all there the wiring is also in the dash harness.
All you need to do is buy a wiper/washer switch and install it in the dashboard where it belongs in the space under the speedometer. The wiring and plug for the wiper/washer (and the fog lights and possibly the rear defroster) should already be in the dash harness. You just remove the little 'cutout' from the blank panel that can hold the fog light switch, rear defroster switch and the wiper/washer switch. You remove the little panel and cut it out from the back. Pop in the correct switch which was used in the YJ's of the time and the XJ's also, and wella! you have wipers.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 4 Old 04-06-2010, 08:09 PM
SkullTripper
1987 YJ Wrangler
I'm fixing to cut my wires and just match the colours together I'll tell you how it goes (I'm not recommending you do this) also fill out your profile please sir and welcome to the forum
Its a Jeep thing....
My 1987 Jeep Wrangler Build..
SkullTripper is offline
post #4 of 4 Old 04-07-2010, 08:21 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Here is a picture of what a '95YJ HT plug looks like. Yours could be similar:
wiring a harness for rear wiper on 94 Roadyy YJ Wrangler Technical Forum 1 03-24-2010 08:24 AM
a new rear wiper defroster wiring question tenax YJ Wrangler Technical Forum 23 05-26-2009 10:37 AM
Rear Wiper wiring specifics... Alexia TJ Wrangler Technical Forum 1 11-13-2008 11:04 AM
wiring rear wiper switch from XJ to my YJ cueball YJ Wrangler Technical Forum 3 10-03-2005 06:17 PM
