Rear Window Defogger - JeepForum.com
post #1 of 5 Old 11-12-2007, 06:47 PM Thread Starter
Mark100
I recently got a 95 Wrangler. The rear defogger doesn't work, but the fuse is fine. Does anyone know what is in the circuit? I know there is obviously the switch and light bulb for the switch, and I know where it connects to the fuse panel. Am I missing anything?
Mark100 is offline
post #2 of 5 Old 11-15-2007, 05:14 PM
Sahara95
I had a similar problem with my hard top. It turned out that the electrical connections that run thru and connect on the ends of the door/window shocks were not making a good connection. After I cleaned the spade style connections(all 4) the heating elements worked fine. It may not be your problem but it may be worth looking at.
Sahara95 is offline
post #3 of 5 Old 11-15-2007, 07:09 PM
Burnerman
Burnerman's Avatar
I believe there is also a timer/relay near the fuse panel for it. I think it's red? Does the light on the switch come on? Do you get 12v to the wires coming out of the hardtop? Is the hardtop plugged in? Is there power at the plug that plugs into the hardtop? Does the hardtop rear light work?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 5 Old 11-15-2007, 08:00 PM Thread Starter
Mark100
Thanks folks- Yes the rear light works, so I'm guessing the hard top is plugged in (the windshield wiper also works). The light goes on on the defogger switch, and I believe the relay works because the light on the switch turns off after 10 minutes. So I'm assuming I need to look at the connections or the wires going from the fuse box.
Mark100 is offline
post #5 of 5 Old 11-16-2007, 11:09 AM
Piet
Put a test light (or voltmeter) in the connection...
- Peter ----------- Canadian Jeep Club Member
- 3.8L V6, 6 Spd Manual, RockTrac with Dana 44's on 32's. Mostly stock for now...
- 350 TBI, NV4500, Dana 300, Detroit Locked Dana 44, Spooled 9", SOA, 37" MTR's
- 4 Cylinder Stocker on 31" Kuhmo MTs
Piet is offline
Rear Window defogger not working Jazzrider TJ Wrangler Technical Forum 3 03-25-2009 05:11 PM
Rear window defogger Jazzrider TJ Wrangler Technical Forum 5 12-12-2007 06:23 PM
YJ Rear Window Defogger Fuzz YJ Wrangler Technical Forum 1 11-12-2003 05:36 PM
Rear window defogger connector came off tdp1 TJ Wrangler Technical Forum 8 04-07-2003 07:07 PM
Rear window defogger tdp1 TJ Wrangler Technical Forum 2 04-07-2003 06:38 PM
