Rear Wheel Stud Replacement - JeepForum.com
post #1 of 10 Old 02-28-2010, 03:27 PM Thread Starter
1995Moneypit
Getting some conflicting info on how to replace a rear wheel stud. Anything from just hammering them out to having to pull the axle out. Do I just need to remove the brake drum, "tap" the bad stud out, and put the new one in?
1995Moneypit is offline
post #2 of 10 Old 02-28-2010, 04:11 PM
wrangler76
If you remove the whole drum brake assembly there's enough room to knock out the stock length studs on a dana 35c.....
wrangler76 is offline
post #3 of 10 Old 02-28-2010, 04:15 PM
Opihi59
from here it gets rough
Opihi59's Avatar
.....which can make getting the new ones in rather interesting, because they have to seat into the holes in the flange and it can be painful trying to seat them. What I have done with mine is to pull the axles, hammer, or press out the old ones, and hammer/press in new ones, then re-instll axle. This technique is what I'd recommend.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 10 Old 02-28-2010, 04:25 PM
wrangler76
I've pulled them on using a nut, vice grips and a stack of washers for spacers. The 1/2" lugs do much better than the 7/16's using this technique....
post #5 of 10 Old 02-28-2010, 05:15 PM Thread Starter
1995Moneypit
What about pulling them off--need to pull axle?
post #6 of 10 Old 02-28-2010, 06:11 PM
wrangler76
Nope.... Stock studs are 1.75" long and you have about 2" behind the axle flange with the shoes and other brake parts removed.... so just smack it with a 3# sledge and it should fly out the back side.... then you can "press" the new one in as stated above....
post #7 of 10 Old 02-28-2010, 06:21 PM
Burnerman
Burnerman's Avatar
I installed 10 new wheel studs on my buddies new axle shafts. We used a stack of washers, lugnut and the impact to pull the studs into the flange. We also pulled the threads out of 2 lug nuts in the process. If you just need to replace 1 broken stud bang it out and pull it in with the washer/ nut trick. If you're doing all 5 pull the axle and use a press.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #8 of 10 Old 03-07-2010, 04:50 PM
GringoLoco
GringoLoco's Avatar
Late reply, but maybe still useful. I just did this yesterday. I smacked it through with a BFH, lined the new one up, and then carefully put the wheel back on. I then held the threads with a large flathead screwdriver and started the lugnut. I was then able to get it to bite enough to tighten the lugnut, which pulled the stud through. Only took a few minutes.
GringoLoco is offline
post #9 of 10 Old 03-07-2010, 04:56 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I use a wheel stud installation kit I got at sears for about $35. Works everytime flawlessly.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #10 of 10 Old 03-09-2010, 05:50 PM Thread Starter
1995Moneypit
GringoLoco--
Did you have to take the brake hardware out?
TJ Front Wheel Stud Replacement sargeek TJ Wrangler Technical Forum 3 07-26-2010 02:04 PM
Rear wheel stud replacement Prot JK Wrangler Technical Forum 3 01-07-2008 08:29 PM
wheel stud replacement help UTmike TJ Wrangler Technical Forum 12 11-07-2006 11:00 AM
Broken Rear Wheel Stud, Need Help cantthinkofname TJ Wrangler Technical Forum 6 06-04-2005 12:44 AM
Wheel Stud Replacement jeep_mike TJ Wrangler Technical Forum 2 04-26-2005 06:27 AM
