rear wheel bearing - JeepForum.com
post #1 of 8 Old 11-23-2011, 07:23 AM Thread Starter
19renegade91
rear wheel bearing
im on a phone and its really hard to search if someone is free it would be great to know somthin about yhe rear wheel bearings . or post a link to somthing.
19renegade91 is offline
post #2 of 8 Old 11-23-2011, 07:53 AM
scubamc
What would you like to know about the rear wheel bearings?
scubamc is offline
post #3 of 8 Old 11-23-2011, 09:32 AM Thread Starter
19renegade91
how to change
post #4 of 8 Old 11-23-2011, 09:45 AM
tdewit
http://www.amazon.com/Wrangler-1987-2008-Haynes-Repair-Manual/dp/1563927969 ? You shouldn't be without this or even better, the FSM
tdewit is offline
post #5 of 8 Old 11-23-2011, 09:49 AM
scubamc
If you are still running the dana 35 you will need to
Open and drain fluid from the dif.
Jack up the Jeep
Remove tires
Remove brake drum
Remove the carrier cross pin
Push the axle shafts towards the carrier and Remove C-clips
Remove axle shafts
Remove axle seal
Insert bearing removal tool
Use a slide hammer and remove bearing
Clean up the bearing area and press in the new bearings.
Reverse all the steps and you should be done.
If this is not enough info there should be some videos on youtube and google is your friend.
scubamc is offline
post #6 of 8 Old 11-24-2011, 01:27 PM Thread Starter
19renegade91
so i hear i should ditch the dana35 for a ford .. is this the whole axle tube assembly or just the insides
post #7 of 8 Old 11-24-2011, 01:30 PM Thread Starter
19renegade91
yes theres too many words in the haynes manual it clouds my judgement lol . much easier to folow ur list lol to many years are covered in them and its confusing is there a better book than haynes
post #8 of 8 Old 11-24-2011, 04:54 PM
pasinbuy
The job is not that hard to do. Borrow the bearing removal tool from Advanced Auto.
The only slightly tricky part is after you pull the pin on your rear end to remove the C clip. Be careful not to turn the wheels or the gears inside may fall. Take a good close look at what you have there just in case they do, and make sure that the shim is put back where it belongs. In fact block up the wheel that you are not working on to help you not let that happen.
If your rear end oil is fresh just catch it and put it back in. Knowing that you are 21. When you do this job you will know that you can do anything. It is not hard, just a bit scary for a novice. Go for it.
pasinbuy is offline
