Rear Upper Shock Mounts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rear Upper Shock Mounts
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Memorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 01-22-2010, 06:33 AM   #1
mrlbro616
Ok, so everything I can find out there tells me how to buy the adapters for the rear upper shock mounts. I want to replace the factory onesthat are completely rusted out. Can anyone tell me where I can get replacements? Anyone have pics of them doing this?
Chevy Blower Upgrade, New Upper Shock Mounts, New Lower Shock Mounts, New Track Bar Mount, New Shocks...still not done...
-If your kidneys aren't bruised you aren't driving a YJ!
mrlbro616 is offline   Reply With Quote
Unread 01-22-2010, 07:02 AM   #2
monkeyhouse
Fun stuff, huh? I had an upper mount break last week. I've been bounce around ever since trying to find a fix. I did find this and am going to look into it more today.
Teraflex 001234800 - TeraFlex Revolver Rear Shock Bar for 87-95 Jeep® Wrangler YJ - Quadratec
This says it only requires the lower mount to install. I am going to call them today. I need shocks something awful too.
1989 YJ, 6 cylinder 4.2L , 258. replaced cooling system, Nuttered and TeamRushed, Weber 38 DGES, Thanks to S.R. Wilson, Sr. for GIVING me a skid plate!
monkeyhouse is offline   Reply With Quote
Unread 01-22-2010, 07:10 AM   #3
iowajeepers
My mounts weren't completely dead, but I bought the MORE extensions and welded them to the frame. I had to grind on them some, but it seems to work well.
Rear Upper Shock Mounts for Jeep YJ Wranglers
Cars.
iowajeepers is offline   Reply With Quote
Unread 01-22-2010, 07:16 AM   #4
TSEJEEPERS
By the instructions it looks like that bar attaches to your original upper shock mount.
That I know of the only thing you can do is grind the old off and weld on a new one.
Maybe you could use something like this?
Front Shock Mounting Bracket and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Unread 01-22-2010, 07:31 AM   #5
mrlbro616
not complaining or anything but....monkeyhouse,this isnt a replacement its an alteration....iowajeepers, this fix assumes that the rear mounts are already existing, which they aren't....Tsejeepers, these are for the front. I'm looking for the parts that I can cut off the old ones and weld on the new ones.
Unread 01-22-2010, 07:32 AM   #6
Mark05059
On a privious jeep I welded a piece of channel to the frame with upper shock bolt welded to the inside so it looked like ]-
I know bad picture but you get the idea..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote
Unread 01-22-2010, 07:47 AM   #7
TSEJEEPERS
When I stretched the rear I made my own upper shock mounts.
I know those that I have listed are for the front. I do not know why they would not work on the rear though.
Unread 01-22-2010, 10:06 AM   #8
yakak28
Does it look something like this?
What a pain in the a s s.
yakak28 is offline   Reply With Quote
Unread 01-22-2010, 12:37 PM   #9
mrlbro616
Looks exactly like the part that TSEJeepers is referring to....broke off just above the frame rail...gonna look around for someone else that carries that part...theirs is on back order and I'm going up to fix the jeep next saturday!
Unread 01-22-2010, 01:33 PM   #10
yakak28
Let me know what you find, because mine is sitting in the garage awaiting repair. I've been looking around for someone to fabricate or purchase a replacement I the cut the remaining fixture off last weekend with a Sawzall and Multi-Master. Wasn't too difficult.
Unread 02-05-2010, 03:30 PM   #11
mrlbro616
Ok, So, lower mounts came from Iron Rock Off Road, upper mounts came from quadratec. They are actually the front upper mounts for the 76-81, however with a little grinding to adjust for the frame rails they work great. For the Track bar we used a 3 inch box tube steel and cut the one side off so it could fit down over the axle, then we welded two vertical pieces of 1/4 inch steel and drilled through it to mount the track bar to. Works great, added 4 new shocks and a floor pan to the driver's side. Less breezy in the Jeep and more comfortable.yakak, I'm tring to figure out how to get pictures on here, but if you want to me to email you pics, I will.
Unread 02-05-2010, 03:38 PM   #12
TSEJEEPERS
Just getting a red x.
Host it on Photoshop then post the URL. If you do not have enough posts for the pictures one of us will post it for you.
Unread 02-05-2010, 03:55 PM   #13
yakak28
Yeah man. Shoot me some pics. I PMed you my email addy.
Thx.
Unread 02-05-2010, 04:09 PM   #14
mrlbro616
<img src="http://api.photoshop.com/home_c0fc09...4493d6d89e9918" width="1600" height="1200"/>
<img src="http://api.photoshop.com/home_c0fc09...28d4d15b578711" width="1600" height="1200"/>
<img src="http://api.photoshop.com/home_c0fc09...61113f3963fa1d" width="1600" height="1200"/>
<img src="http://api.photoshop.com/home_c0fc09...45ae9785b9951c" width="1600" height="1200"/>
Gonna Try this...will post more tomorrow if I can get around to it.
Unread 02-05-2010, 04:29 PM   #15
timatoe
Here ya go....
And read this.... http://www.jeepforum.com/forum/f29/h...pforum-574312/
timatoe is offline   Reply With Quote
