Rear U joint Problem-vibration while towing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rear U joint Problem-vibration while towing
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 11-04-2008, 09:09 AM   #1
maxatack
Help I am on the road to Florida and towing my YJ. So here is the problem-the rear u joint is worn and causing a vibration. Can I pull the drive shaft off with out the transmission leaking and continue on down the road. Quick info or opinions would be appreciated. Thank you - Skip
maxatack is offline   Reply With Quote
Unread 11-04-2008, 09:17 AM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Take the rear bolts off the diff yoke and Zip tie the shaft up out of the way. If you pull the shaft( it will come out if you don't zip tie it good) it will loose the tcase fluid.
Are you flat towing??? I would unbolt both shafts anyway, just to be safe.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
