Quantcast rear tires toed out.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rear tires toed out..
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 12-05-2007, 01:50 PM   #1
danheit
1979 CJ7
My rear tires are toed out at the bottom, making the axle appear to be bent downwards in the center, but after checking it several times, it isn't. The wheels don't seem to have any slop in them, which makes me think that there are no bearing issues, as is also that the seals aren't leaking. Anybody have any ideas? I will get a pic asap.
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7 Blue Jeep
danheit is offline   Reply With Quote
Old 12-05-2007, 03:52 PM   #2
ONEMORE2
Get a straight line under the rear end the check it ,sounds to me the rear end is bent it would be nice if you could get it on a frame rack to measure it.
88yj, incubus off road wheels,32"tsl radial super swampers,2.5" pro comp lift ,kc lights,rock lights,8000lb.mile marker winch,best top bikini top,nutterbypass,lock right locker in the rear,TJ flares,poison spyder rock rails,home made front flat fenders,Skyjacker nitro 8000 shocks,procomp rear bumper,CB.more to come.
92yj,black with flame job.I have now added a 2003 wrangler,2"BB,dick cepek wheels ,trail armor all four corners,33" BFG-AT's.life is good.
ONEMORE2 is offline   Reply With Quote
Old 12-05-2007, 06:55 PM   #3
danheit
1979 CJ7
Can't imagine what would have bent the rear axle though. Haven't taken it off road in several months....
Old 12-05-2007, 09:58 PM   #4
jeeepguy
jeeepguy's Avatar
If its a D35 you could have driven over a curb roughly or hit a pothole just right and bent it. The axle tubes are really poor on them.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote
Old 12-06-2007, 07:52 AM   #5
danheit
1979 CJ7
Well that sucks.
Old 12-06-2007, 08:23 AM   #6
GrimJeeper91
I had to have my D35 housing straightened when the locker was installed. Years later it was noticeably bent when it was pulled for the D60 install. While I wheel some pretty rough trails I drove it real easy for fear of breaking it. So yes, the housing is weak.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote
Old 12-06-2007, 09:53 AM   #7
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I agree that a bent axle housing is the only thing I am aware of that would cause that problem.
If it is bent enough to cause uneven tire wear I'll bet if you get behind the jeep the bend might be noticable to your eyes. Post a picture.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 12-06-2007, 12:32 PM   #8
grenMEG
Try, jacking it up just to make sure your c-clips didn't come off or that you didn't twist or break an axle shaft. Hate to see a Thread "SAW my Wheel and axle pass me on the HIGHWAY!"
grenMEG is offline   Reply With Quote
Old 12-07-2007, 03:26 PM   #9
danheit
1979 CJ7
I know this picture sucks, but I keep forgetting my camera at the office, so here is my cell phone pic. You can see that the left wheel is pretty tweaked, but I am unsure if it is the tire itself, as these are used tires (although not that used), or if it is the axle. These tires have been on here for about 9K miles. Never noticed this with the stockers on there, but who would?
Old 12-07-2007, 04:13 PM   #10
red87yj
1987 YJ Wrangler
it does look like the drivers side is tweaked. see if you can get a pic of the axle its self. if the axle is tweaked, what are the chances you have a junk yard near you could get a new axle at?
Later
Zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift
red87yj is offline   Reply With Quote
Old 12-07-2007, 07:24 PM   #11
doug_1994
My 1st 35 (factory) kept giving me problems. I just got a junkyard one to replace it ($150). I didn't have access to a frame machine, or any jig. I put the old one on a set of steel sawhorses a rolled it around. It was really noticable with the backing plates moving back, and forth.
In that pic, it does look bent.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline   Reply With Quote
Old 12-07-2007, 07:45 PM   #12
danheit
1979 CJ7
Later
Zach
The last junk yard to get a jeep around here waited 2 years to get it, and then sold the rear axle for $1400. It was a TJ. I think I will just go after an 8.8 or a 9. After all, if I have to buy a new one....might as well go big(ger) or go home!
Old 12-07-2007, 10:31 PM   #13
iwishihad1
yep..looks bent. d35s are a dime a dozen. try finding one for cheap, and if you cant just upgrade to a ford 8.8. find somebody who doesn't know what theyre worth for jeepers, and buy one. me and my friend each picked ours up for 200 bucks. great buy
[CENTER]1995 fire red XJ, new 4.0, ARB safari snorkel, sye, front DS, aussie locked 8.8 5:13s 38 SXs, trussed/locked 44 front, hydro assist, DOM steering/COLOR]
YJ. 91 body, body off resto, crate chevy 350, 700r tranny, 2 inch springs, SOA, ford 9 rear, dana 44 front, both detroits, cage, 4:88s, and 36X14.50s. strictly street queen
iwishihad1 is offline   Reply With Quote
Old 12-08-2007, 09:13 AM   #14
AirForce
Head Hunter
AirForce's Avatar
I bought a 94 Wrangler a couple months back, and my rear wheels did the exact same thing. After measuring the differential housing tubes, it was bent... and it was leaking fluid from the left tube where it attaches to the differential. I bought a used housing this last week and I'm changing it out this weekend. We are swapping the same gears into the new housing so I don't have to worry about a missmatch with the front differential.
I talked to a couple local shops about bending the housing back into shape, but they advised against it, especially since it was already leaking.
Good luck in your search for a used housing!
AirForce is offline   Reply With Quote
Old 12-09-2007, 07:17 AM   #15
red87yj
1987 YJ Wrangler
search around for an 8.8 with matching gearing to your front. thats what i did, i got a 8.8 with 3.55's and didn't have to re gear. it saves a lot of work and down time. look around at you pull it yards, the one that i go to has $50 rears, that is disk to disk. also while you are there, see if you can find a drive shaft out of a late model 4wd ranger, its a hell of a lot better than ******* the cost of a new part (about $50 if i remember correctly). there is also some ford van with the part, but i have no information on that. good luck with it.
Later
Zach
PS. i don't know why but the missing text involves dinner ware as a verb.
3.5 BDS Lift
Glock Forum
