Rear tire wobble?? - JeepForum.com
post #1 of 4 Old 04-07-2010, 07:51 AM Thread Starter
bscline09
Rear tire wobble??
I was driving down the highway the other day and got stuck in traffic. I was creeping and looked back and glanced at my rear tire on the driver's side. It was wobbling. I knew that I have taken it offroad but not too extreme. My Jeep is stock (hopefully getting a lift and tires this summer once I convince my wife). I have not done much to it and have only 125,000 on it. I called Jeep and they said I need a new axle sleeve and axle bearing. I thought it would only need a wheel bearing. I lifted it up once I got home and could barely get a wobble when I pushed in on the top of the tire. Does anyone know what is going on? I first thought the wheel was bent but now I found a wobble, I aint sure. Any suggestions?
bscline09 is offline
post #2 of 4 Old 04-07-2010, 08:01 AM
Pat80CJ5
1980 CJ5
Start with the cheapest solution and work your way up. What Jeep people did you call? Do you know anyone in a Jeep club? Start with them.
Pat80CJ5 is offline
post #3 of 4 Old 04-07-2010, 08:05 AM Thread Starter
bscline09
No I havent tried them yet. Not sure really where the local one is but I called the Parts departments for Jeep. And by the way, its only one tire wobble. Its not both tires wobbling so I thought it would only be one wheel bearing but thanks for the help guys
post #4 of 4 Old 04-07-2010, 08:22 AM
Louie4
"You pass butter"
Louie4's Avatar
Try swapping another wheel you know isn't wobbling on that side and see if it wobbles. If so then you have an axle issue. Possibly bent axle shaft flange?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
I did a very stupid thing. (wobble in rear wheel/tire) rmv42158 TJ Wrangler Technical Forum 46 03-26-2010 01:21 PM
Slight wobble in right rear tire in my TJ LMG23 TJ Wrangler Technical Forum 30 02-20-2010 09:36 PM
Rear Tire Wobble digizure YJ Wrangler Technical Forum 7 05-15-2007 08:56 AM
Tire wobble asc TJ Wrangler Technical Forum 2 10-26-2006 07:05 AM
Bad Tire wobble Negative6 TJ Wrangler Technical Forum 4 07-04-2005 05:40 PM
