Rear Tcase Fork Sprays ATF. - JeepForum.com
post #1 of 12 Old 06-12-2013, 12:42 PM Thread Starter
Delta347
So I installed a Rugged Ridge SYE on my 1990 NP231J and drove fine for about 250 miles then at 263 I went under cuz my speedo stopped working (I used a 1995 harness) and when I went to readjust the speedo housing cuz it's a 29tooth and not a 36 tooth like I need (4.10 gears on 31.65 inch tires) I noticed that there was this awkward fluid on the muffler and in a spray line over the underbelly. Any ideas?? I notice the fork can wiggle a small amount in and out. The seal was dry when I touched it. The inside of the fork was a little wet like where the u joint sits. I haven't removed my t-case drop since installing the cv shaft and t-case but that wouldn't cause this would it?
/End Transmission
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #2 of 12 Old 06-12-2013, 01:03 PM
Jeepsr4me
Did you put that rubber star washer on? Or it could be the muffler is heating grease up and making it sling out.
Grease the U joints to be sure..
Jeepsr4me is online now
post #3 of 12 Old 06-12-2013, 04:30 PM Thread Starter
Delta347
Well the grease is red and the ATF is red and whatever it is won't burn off the muffler it just stays...
However when I handle it after letting the exhaust cool remains very very viscous.
I don't remember this kit coming with a star-washer and pictures I'm looking at in the manual don't have one.
Delta347 is offline
post #4 of 12 Old 06-12-2013, 07:44 PM
Louie4
Just keep an eye on the fluid level of the t-case and look for red drips on the driveway. Maybe put a piece of white cardboard underneath or something. From the picture it doesn't appear to be a major issue.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 12 Old 06-12-2013, 08:49 PM
jerresredyj
I think this might be the star washer Delta is referring to.
http://www.advanceadapters.com/produ...r-seal-washer/
jerresredyj is offline
post #6 of 12 Old 06-12-2013, 08:52 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, that's it.
Without one, it's not uncommon to have fluid leak through the splines.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #7 of 12 Old 06-13-2013, 08:20 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I've seen my share of chewed up seals out the front yoke and for that a little rtv will seal it up on top of the old rubber.
Anticanman is offline
post #8 of 12 Old 06-13-2013, 02:59 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Be sure what fluid it is, don't just assume ATF. It could be u-joint grease, which can be red too. Might be a bad muffler bearing too.
[I made that last part up.]
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #9 of 12 Old 06-13-2013, 03:39 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Blinker fluid leak, Don?
post #10 of 12 Old 06-14-2013, 03:02 AM Thread Starter
Delta347
Originally Posted by Mean Max
Yep, that's it.
Max
So do I just need to buy one of those washers and install it? I'm not familiar with where exactly it goes but it looks vaguely familiar and I think my old one got reused and was rather beat up....
/End Transmission
Delta347 is offline
post #11 of 12 Old 06-14-2013, 05:34 AM
jason280
Yes, it will likely clear up your leak (assuming its coming from the SYE end). Just run a dab of RTV around the collar behind the rubber washer, finger tighten and let sit for an hour, then torque down the output yoke to 150 lb-ft and you should be good.
jason280 is offline
post #12 of 12 Old 06-14-2013, 07:24 AM
UZI4U
The AA part is the best price I can find. Of course the shipping is more. I just ordered four of them and a few U bolts and the shipping was $12.
MCLMM
UZI4U is offline
