Rear SOA attempt - JeepForum.com
post #1 of 26 Old 07-28-2006, 01:22 AM Thread Starter
admar2
admar2's Avatar
Rear SOA attempt
ok, I hacked those shackle hangers back off the rear end, and got the itch to try something.
I moved the springs over the axle in the rear. gained a bit of lift for sure. I'm trying to decide if I like the way it sits now or not. these springs are my stock rear springs, not lift springs.
nothing is welded up yet, just bolted. if I decide to keep it this way, I'll set the pinion angle and weld the new perches and cut the old ones off.
its got a bit of a slope to it. I threw the spare in the back to try and weigh it down a little, plus I figure the new bumper/tire carrier I"m building will weigh near 80lbs.
what do ya guys think?? anyone else SOA in the rear and SUA up front???
I think I'll roll it out of the garage in the morning and make the final decision.
rear height to bottom of frame. anyone know the measurement on their YJ at these points??
front height to bottom of frame
admar2 is offline
post #2 of 26 Old 07-28-2006, 01:50 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I think with the tire carrier...it will be darn near perfect height. I like it.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #3 of 26 Old 07-28-2006, 03:48 AM
jipjip
jipjip's Avatar
your gonna get MAJOR flex in the rear w/ that setup , but make sure you tackle the axle wrap problem w/ a ladder bar or similar.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #4 of 26 Old 07-28-2006, 04:23 AM Thread Starter
admar2
admar2's Avatar
I've got the MORE anti-wrap bar sitting in my garage. gotta figure out a way to put it on the passenger side. the exhaust is in the way right now.
I think I'm gonna leave it SOA, and weld everything up tommorrow and wheel it some this weekend.
admar2 is offline
post #5 of 26 Old 07-28-2006, 04:29 AM
Tomb Raider
Addicted...
These might help you out a bit with ideas for the traction bar.
post #6 of 26 Old 07-28-2006, 04:42 AM Thread Starter
admar2
admar2's Avatar
looks good! is the traction bar as effective if its on the drivers side?
mounting on the drivers side wouldn't be any problem. there's lotsa room on that side.
just out of curiosity, what's your pinion angle at?
admar2 is offline
post #7 of 26 Old 07-28-2006, 04:58 AM
Tomb Raider
Addicted...
Not once have I had axle wrap. The difference between passenger and driver side for mounting is minimal at best.
I believe it ended up being 22~23 degrees. Thats with my 2" lift springs, stock shackles and no tc drop.
post #8 of 26 Old 07-28-2006, 08:31 PM Thread Starter
admar2
admar2's Avatar
alright, got the pinion angle set and the new perches welded on today. also removed the old perches. still need to fix the rear brake hard lines, and install the traction bar.
next to a full SUA YJ on 33's for comparision.
admar2 is offline
post #9 of 26 Old 07-28-2006, 09:01 PM
iking87
is there an advantage to going boomarang shackles when SOA?
also, how do you determine the pinion angle? i am going SOA as soon as i find an 8.8 with 4.10s and discs for the right price ; )
iking87 is offline
post #10 of 26 Old 07-29-2006, 10:07 AM Thread Starter
admar2
admar2's Avatar
there are numerous writeups on how to set the pinion angle online.
http://www.stu-offroad.com/axle/pinion/pinion-1.htm
http://www.4x4wire.com/tech/pinionangle/
admar2 is offline
post #11 of 26 Old 07-29-2006, 04:17 PM Thread Starter
admar2
admar2's Avatar
worked on the crossmember and the brackets for the traction bar this morning.
had a heck of a time figuring out a way to build a crossmember, as the rocktrac transfer case I have is a good bit bigger than stock, and was in the way, seemingly everyway I tried to come up with a crossmember.
here's the result. its 1.25inch DOM, 1/4inch wall. I took two pieces and notched them so they would slide over the MORE shackle bracket.
like so.
then I fabbed a bracket on the other end, to bolt up to the bellyup to frame location
other side in place
both sides in place, center welded up
it'll be fully welded to the bellyup when I'm finished. I hope it'll be strong enough.
admar2 is offline
post #12 of 26 Old 07-29-2006, 07:56 PM
jipjip
jipjip's Avatar
man i wish i new how to weld. that looks well strong enough to me......i love fab work, it's so awesome. looks great man, keep up the good work. next thing to tackle is those bump stops!!! you gotta have correct length bump stops to prevent your springs for negative arching too much, that's what kills springs the quickest, and SOA setups required the lengthening of the bump stops to compensate for the negative spring travel your gonna get.
jipjip is offline
post #13 of 26 Old 07-29-2006, 08:43 PM Thread Starter
admar2
admar2's Avatar
I think I'm just gonna get some 5inch springs for the front, to level it out, and stay SUA up front.
are there any good 5inch lift springs out there?
admar2 is offline
post #14 of 26 Old 07-29-2006, 10:17 PM
Yule16MET
Yule16MET's Avatar
never heard of them, but usually people go sua in back and soa in front but if you did the back and know how to set the angles then why not do the whole thing.
I dream of the jeep, drive the chevy and roush pays for it all
1990 YJ lerado,Soa,2.5R.E.springs,8.8,4.88'sPSC trail cage&rocker nockers w/sliderbars,home made bumpers, 35"boggers,sye, tomwoodsds, revolvers, red & yellow optima, bushwackers,corbeua ss seats,mc2100,juicebox, 3core rad., b&mshifter and highlift,5point harnesses,wheel spacers,9000lb mile marker,ssdash kit,no sway bar, no trackbar, walmart lights,clinometer, XJ passenger shaft, axle tube seals, M.O.R.E track bar
And a Monster Yellow CJ5
40x17's 12"lift full cage
Blackjeepclub #16
Armyjeepclub #16-#1
yellowjeepclub #BIG16
Yule16MET is offline
post #15 of 26 Old 07-29-2006, 11:44 PM Thread Starter
admar2
admar2's Avatar
well, the front flexes fine. the rear didn't flex worth crap before. hence the experiment with SOA in the rear.
I don't wanna have to deal with the steering issues on the front SOA. I have a D30, so hi-steer kits are few/far/expensive.
admar2 is offline
3rd pinion seal attempt plz help Zangief YJ Wrangler Technical Forum 9 06-29-2009 04:25 PM
Revival attempt Moses2564 TJ Wrangler Technical Forum 4 08-11-2008 01:08 PM
First attempt at pics. DShizzle JK Wrangler Technical Forum 14 11-29-2006 04:16 PM
attempt #3 stl_07 JK Wrangler Technical Forum 9 11-15-2006 09:34 AM
anyone else get stuck?first pic attempt EMT YJ Wrangler Technical Forum 10 12-27-2005 09:22 PM
