#1 | |
rear shock relocation brackets??
putting in an 8.8 and want to make bottom mounts flush with bottom of axle tube. is there anyone else other than MORE that makes a set of relocation brackets so i don't have to get shorter shocks. MORE's are like $100. anybody else come up with a DIY bracket that works?
Thanks
91 YJ 4.0 HO, 3.5" BDS, 5/8 MORE Booms, 1" BL, MML AA SYE & CV, 35" Maxxis Bighorn Smittybilt XRC8 Winch, 8.8 W/Elocker, D30 W/Aussie Genright tube fenders |
#2 | |
Jello Puddin'
If you're talking about the upper relocation mount, I don't know of anything right off other than the MORE kit. But, I can't imagine the difference in length going from the stock location to flush with the bottom will be enough to warrant new shocks. As for the shock mounts on the axle itself, I'd recommend Ruff Stuff Specialties.
#3 | |
Ditto on Ruff Stuff mounts.
$15.50 for these! http://www.ruffstuffspecialties.com/catalog/paired-bracket-p-43.html ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#4 |
They just came included in my 8.8 swap kit
But to answer your question, MORE is the only company I have seen that seels the upper extender. You could do an outboard shock relocation, like have some tube bent up and weld it to the outside of the frame. Just another idea
93 YJ - SOLD |
#5 |
Go Kings Go!
This guy made his own...
http://www.jeepforum.com/forum/showthread.php?t=416296&highlight=shock+mount+exte nsion I have the MORE's and love them. They are pricey, but worth it.
95 Black YJ *Build Thread* 2.5L, 4.5" RE springs, MORE hoops 1" BL, 35" KM2's, Tube Fenders, Full Cage, D30 Aussie, TeraLow 4:1, HF 8K Winch Herculiner, Warn steering & Gas Tank skids, LED tail lights, TJ corners, Rock Sliders, Ford 8.8, JCR OTK Steering |
#6 |
sebastian, how hard was it to install the MORE ones. i've heard its a PITA, did you have to remove the exhaust and cut some metal for articulation of new position on pass side?
#7 | |
Go Kings Go!
The grinding of the heat shield took about 2 minutes with my grinder, and removing the exhaust is NOT necessary (at least it was not on mine). Also had to cut a notch on the fuel filter skid along the frame on the driver side.
#8 |
cool thanks, i'd like to make my own but, i'm lazy. i should install these first so i can get the right angle to weld the shock mounts onto axle right?
#9 |
Go Kings Go!
Yep, we installed the upper shock mounts first, hooked up the shocks and let them hang down, bolted the lower shock mounts to the shocks, lined them up, jacked up the shocks until the lower mounts was flush with the axel tube, and tack welded the lower mounts.
#10 |
thats what i figured, thanks.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
