Rear shock mounts broken, cant remove the bolt... ideas? - JeepForum.com
post #1 of 3 Old 12-17-2008, 03:42 PM Thread Starter
BAJER-guy
2011 JK Wrangler
(I'll post pics when I get a moment)
Problem: Rear shock mounts (where the teraflex shock bar mounts) were broken off last off-road trip. (TeraFlex link: Quadratec Item Description
What I've done:
I've tried a bunch of things so far and none of them have worked at all.
  • From what I read around the forum, I gathered that I should be able to hit the bolt that you attach a teraflex shock mount bar to and it should come right out. Well that idea didnt work at all. I had 3 different people hit it with 2 different sizes of hammers and it didnt budge at all.
  • So I figured I'd grind it down as much as I could and then try to hit it out. That didnt work either.
  • So we took an impact hammer to it.. all that did was successfully make a nice dent in it.
  • I tried drilling it out, but the metal is hardened and only made a tiny scratch.
I dont have, and cant use a torch on it to heat it up and then try.
So this generates two questions:
1. How the hell do I get this out? Drilling, Hitting, and Impact hammers dont work.
2. This is a serious question, but ... do I really need shocks at all? I dont plan on going off-road until I do have them back on, but the Jeep is also my DD. Is it okay to drive without rear shocks?
BAJER-guy is offline
post #2 of 3 Old 12-17-2008, 04:08 PM
Godchsr
I drive my Jeep to work every day without the rear shocks on. It's not a big deal. I drove my XJ with none for quite awhile.
I'd cut the bolt off.
Looking for a Jeep again... I just can't stay away
Godchsr is offline
post #3 of 3 Old 12-17-2008, 04:10 PM Thread Starter
BAJER-guy
2011 JK Wrangler
Yeah, the shock bar broke the bolts off for me. I've got new ones that I need/want to replace it with (grade 8, 5/8 bolts), but I cant get the damn old ones out...
Thanks for info about the shocks. Oh, I do have SOA, w/o shocks does that increase chances of spring-wrap or do the chances remain the same?
Broken rear shock bolt gsc0527 TJ Wrangler Technical Forum 26 03-26-2012 07:15 AM
Broken shock mounts 93yjjeepnwv YJ Wrangler Technical Forum 3 08-26-2008 02:20 PM
remove broken bolt from rear track bar bkeast17 TJ Wrangler Technical Forum 4 09-03-2006 01:25 AM
HELP- Broken Bolts On Upper Rear Shock Mounts 97 sahara TJ Wrangler Technical Forum 7 04-02-2006 12:55 PM
help! Snapped a bolt that mounts rear shock! ClemsonJeepGC TJ Wrangler Technical Forum 8 02-26-2006 11:17 PM
