Rear shock broken off frame - JeepForum.com
post #1 of 11 Old 04-03-2010, 12:07 AM Thread Starter
driftbandito
I was driving my yj when all of a sudden the rear shock started dragging on the ground. I looked under my jeep and noticed that where the rear shock connects to the frame is completely broken off. What could have caused this, the frame is relatively rust free and is there any way to fix this? thanks
driftbandito is offline
post #2 of 11 Old 04-03-2010, 12:20 AM
Tradewinds
Had the same thing happen just a couple of weeks back. Cut one off of a YJ at the wrecking yard and welded it on. The shock mount on my 91 was installed so that it held water and it just rusted from the inside out. I drilled a hole in the base of this one and on the other side so the water will drain out. Just one more of the poor design features that make the early YJs such a joy to own.
Tradewinds is offline
post #3 of 11 Old 04-03-2010, 12:38 AM
ryans93
Thats funny, just today I was driving down the street and saw a yj with the rear shock almost dragging on the ground. I thought it was a bit odd. Apparently this is a common problem.
It should be fine as long as it was "gently" rolled...
1993 YJ 4.0L 5spd Manual. OME 2.5" with 3/4" M.O.R.E Shackles & 1"BL
Not to mention the body doesn't match the frame that doesn't match the engine...
ryans93 is offline
post #4 of 11 Old 04-03-2010, 12:51 AM
RockWoRM
RockWoRM's Avatar
Considering most YJs are 15-20+ years old. Last season, my front spring hanger broke right in two... and I have zero rust. Things break.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 11 Old 04-03-2010, 04:43 AM
Dhofstet
1973 KK Liberty
Yeah i broke both off a few months back driving down some stairs. Don't ask.
I had a shop fab up some new mounts. Cheap as free.. I do not know how to weld yet or i would have done it myself.
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
post #6 of 11 Old 04-03-2010, 05:04 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You don't need an 'official' junk yard bracket. All you need is enough steel to hold a pin in the correct spot. I made this for mine.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #7 of 11 Old 04-03-2010, 05:23 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Hey Don, If at somepoint you are under the Jeep, can you take some measurements for height and distance away from the frame that needed to be??? I have plans for making bolt on replacements but lost the info on dimentions.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 11 Old 04-03-2010, 06:27 AM
JeeperDon
JeeperDon's Avatar
Originally Posted by rustywrangler View Post
Hey Don, can you take some measurements for height and distance away from the frame that needed to be???
Sure, later today, I'll PM you. I moved them a bit up and a lot further forward to tuck the top of the shock into the corner of the 'step' in the tub from front floor to back floor. The photo was when I was swapping my frame a couple years ago, did all the new (used) frame prep first for a month.
Web Admin for
post #9 of 11 Old 04-03-2010, 12:42 PM
djsmith1174
Mine broke off on the axle mount a couple of years ago. You may want to look at the shock and make sure it is not binding. I replaced mine just as insurance that it wasn't the case after rewelding the mount.
djsmith1174 is offline
post #10 of 11 Old 04-03-2010, 01:27 PM
NHfireLJ
NHfireLJ's Avatar
Mine has none...The PO welded a bar between the frame and the shocks are 3" shorter than they should be..so while contemplating welding up my own, I found these at my local crown shop.... $16 each
gonna install them this week.
NHfireLJ is offline
post #11 of 11 Old 04-03-2010, 03:28 PM
YJames90
YJames90's Avatar
Heres my rear upper mount
My 2.5 to 4.3 swap thread
YJames90 is offline
Broken rear shock bolt gsc0527 TJ Wrangler Technical Forum 26 03-26-2012 06:15 AM
Broken rear shock mount timatoe YJ Wrangler Technical Forum 14 08-04-2008 04:28 PM
rear shock braket broken ajsaurus_rex YJ Wrangler Technical Forum 3 05-27-2008 08:44 PM
Broken rear shock mount phylodog YJ Wrangler Technical Forum 14 03-30-2008 01:06 PM
Rear Shock Broken rick95 YJ Wrangler Technical Forum 6 03-14-2005 10:23 PM
