Rear Shock Broken - JeepForum.com
post #1 of 7 Old 03-14-2005, 09:04 AM Thread Starter
rick95
Rear Shock Broken
So im walking up my drive way from getting the mail and i see somethign dangling from the bottom off my jeep. so i check it out and turns out the bracket that held my rear right shock broke off and now my shock is scraping the pavement.
my question is, can i buy a new bracket and put it on my axle with bolts, or is it a weld type of job? Also, what could have caused this, a large pothole? Is it worth just welding the old plate back together?
Any help appreciated
green 95 4-banger
4" RE lift, 33X12.5 Kumho venture M/T, Cragar soft 8's, PORC SYE, wood's shaft
rick95 is offline
post #2 of 7 Old 03-14-2005, 01:54 PM
JungleLarry
JungleLarry's Avatar
It's going to require a welder to fix that.
Look at my monkey.
JungleLarry is offline
post #3 of 7 Old 03-14-2005, 02:32 PM
spydermonkey
spydermonkey's Avatar
I had both of mine break off. I think it was from my shocks being to short. I bought new mounts and had them welded on and bought longer shocks. No problems since. Rubicon Express has some.
http://www.rubiconexpress.com/dynami...p?folderid=227
spydermonkey is offline
post #4 of 7 Old 03-14-2005, 03:00 PM
mfw1fan24
I think this is a pretty common problem
Mine also broke on my 87
Get it welded or maybe weld a small plate to it
mfw1fan24 is offline
post #5 of 7 Old 03-14-2005, 04:35 PM
sjlplat
Same problem. Broke my right rear, but it's so bad it can't be rewelded.
sjlplat is offline
post #6 of 7 Old 03-14-2005, 04:49 PM
bane51031
Have a 95 YJ had 1 break, weld back on and reinforced, then it bent and the other broke. Went ahead and got new mounting brackets and welded on and changed shocks no problems since.
bane51031 is offline
post #7 of 7 Old 03-14-2005, 10:23 PM
jeepramnauth
2010 JK Wrangler
do what bane did, get some brackets.
jeepramnauth is offline
Broken rear shock bolt gsc0527 TJ Wrangler Technical Forum 26 03-26-2012 06:15 AM
Broken Rear Upper Shock Bolts?? BAJER-guy YJ Wrangler Technical Forum 6 11-18-2008 01:20 PM
Broken rear shock mount timatoe YJ Wrangler Technical Forum 14 08-04-2008 04:28 PM
rear shock braket broken ajsaurus_rex YJ Wrangler Technical Forum 3 05-27-2008 08:44 PM
Broken rear shock mount phylodog YJ Wrangler Technical Forum 14 03-30-2008 01:06 PM
