Rear seat mod into two buckets - JeepForum.com
post #1 of 4 Old 06-09-2010, 06:51 PM Thread Starter
tater_kamik
My thought is to take the stock frame for the rear from a yj, add some mounting points for say a pair of dodge neon bucket seats without rails so they are not adjustable. This would allow use of the factory mounting points and easy removal. Has anyone done something like this? And if so, any write ups or random information?
tater_kamik is offline
post #2 of 4 Old 06-09-2010, 09:15 PM
BlackRhino
BlackRhino's Avatar
Here:
My homemade rear fold & tumble bucket seats - Jeep Wrangler Forum
That's the only thread I've found of successfully doing this, however I'm sure there are others.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #3 of 4 Old 06-10-2010, 05:39 AM Thread Starter
tater_kamik
Interesting, I like it! It looks a lot like what I have been thinking about doing actually except that I want to use the base of the factory rear seat so that it comes out just like it was factory equipped. I just need to find a seat that is in bad need of upholstery so that it will be cheap and so I wont feel bad hacking it up. Thanks a ton for finding that! It gives me some ideas...
post #4 of 4 Old 06-10-2010, 06:36 AM
sloan74
That's a pretty slick mod...
sloan74 is offline
Rear TJ upper coil buckets??? crushtheogre TJ Wrangler Technical Forum 2 02-23-2014 07:42 PM
Rear Shocks Hitting Coil Buckets shortydog33 TJ Wrangler Technical Forum 4 08-07-2009 10:32 PM
Swap rear bench for buckets? blueteej TJ Wrangler Technical Forum 5 02-26-2007 06:45 PM
rear seat(s).. .buckets? cueball YJ Wrangler Technical Forum 3 06-28-2006 08:07 PM
Axle rotation to correct rear spring buckets kpatrick TJ Wrangler Technical Forum 4 07-12-2005 08:33 AM
