Rear Seat Belt question - JeepForum.com
post #1 of 10 Old 06-04-2010, 11:26 AM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
I have a 93 yj tub with a family roll bar. There is no rear seat, retractable seat belts are on the roll bar front and rear. There are no "female" seat belt buckles in the rear. Do these mount to the floor like the front ones or to a seat? Thanks.
nedmoore is offline
post #2 of 10 Old 06-04-2010, 11:30 AM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
They bolt to the floor. You should see a bolt hole pretty much right behind where the rear seat ends, right in the middle of the tub.
SimonTuffGuy is offline
post #3 of 10 Old 06-04-2010, 12:04 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
How many holes Simon? Two?
nedmoore is offline
post #4 of 10 Old 06-04-2010, 12:37 PM
YJhobby
Just one... both belts are bolted to the tub with one bolt. Its basically right in the center of the rear portion of the tub
~Steve~
Originally Posted by SnowdogMarc
YJ's don't get stuck....they get temporarily impeeded in their forward progress.
I'm patiently waiting for the "foot-in-mouth" moment to end... but since I've posted, its not today
YJhobby is offline
post #5 of 10 Old 06-04-2010, 03:10 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Found it! Any pics of how the seat belts look with the rear seat would be appreciated....
nedmoore is offline
post #6 of 10 Old 06-09-2010, 10:27 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Well apparently the YJ rear seat belts (receivers, the female end with the buckle) are a hot item! I have the retractable male ends on my roll bar but was missing the female.
Jeep dealer wanted $100.00 each! Bought a pair from J&W salvage for a $50.00.
nedmoore is offline
post #7 of 10 Old 06-10-2010, 12:08 AM
bscline09
Just also wanted to know if they rear belts come off and how?
bscline09 is offline
post #8 of 10 Old 06-10-2010, 12:10 AM
Dhofstet
1973 KK Liberty
Find your favorite torx bit, and unbolt the anchor point.
Sorry if you were looking for an elaborate explanation with pics. Im lazy.
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
post #9 of 10 Old 06-10-2010, 12:19 AM
bscline09
I can get the anchor points off but at the top on the roll bar, I cant seem to find a place to use that "favorite bit."
Yea, we jeepers love those torx too...
post #10 of 10 Old 06-10-2010, 12:22 AM
Dhofstet
1973 KK Liberty
I am not sure i follow. Are you trying to remove the whole seat belt configuration?
Do you have 3 point belts or lap belts?
Are you trying to remove the Female end or the Male end?
Where the roll bar meets the wheel well you have the black plastic piece that needs to be removed. I believe there are two torx bolts down there.
Then up top, there is a black plastic cap covering the torx bolt.
Use a flat head and pry the black plastic "soda cap" looking thing. then bust out the torx!
Oh yes i love torx. When i am through with my jeep, there will not be a torx left on it. I hate them so much..
Dhofstet is offline
Adding a middle seat belt in the rear seat kheiston TJ Wrangler Technical Forum 7 05-30-2010 09:34 PM
'98 TJ Bolt Sizes: driver's seat and rear center seat belt ah77 TJ Wrangler Technical Forum 3 06-24-2009 06:18 PM
Will an 06 rear seat belt clip fit my 97 seat belts? $lick TJ Wrangler Technical Forum 2 04-30-2009 04:58 PM
Rear seat and accompanying seat belt bolt sizes? bjjfoshizzy TJ Wrangler Technical Forum 2 10-27-2008 06:08 PM
Another Rear seat belt question m-lo YJ Wrangler Technical Forum 7 04-19-2005 08:08 AM
