rear seal still leaking,,,duhh - JeepForum.com
post #1 of 5 Old 04-02-2010, 06:56 AM Thread Starter
ncmtns
After 5 cussed hours I had my new rear main seal in, started the jeep, it was leaking like a sieve. Did I put the upper seal in wrong? The lower seal only goes in one way. Or maybe I put the bearing cap on backwards? I dunno. Regardless, I guess I need to buy a new bearing set? Anyone make this goof before?
ncmtns is offline
post #2 of 5 Old 04-02-2010, 08:20 AM
vector6
somehow you nicked the upper part ill bet... it's easy to do...
you will have to do it again....
good news it will go quicker this time because the job is fresh in your memory
vector6 is offline
post #3 of 5 Old 04-02-2010, 08:40 AM
planedog
Yep, that's how it goes. Some of the Fel-Pro seals come with a plastic tool to help get the top half in w/o cutting it but you need three hands to use it.
planedog is offline
post #4 of 5 Old 04-03-2010, 06:48 PM Thread Starter
ncmtns
Pulled off the oil pan to find a broken gasket. Its broken near the front bearing. Had to put it back together to move it. Guess I will pull it off a third time when I get a new gasket... this is getting crazy
ncmtns is offline
post #5 of 5 Old 04-03-2010, 07:12 PM
jeep108
some folks don't think there worth it but i like the one piece permadry gaskets, for me they're easier to handle and have steel grommets around the bolt holes that are supposed to keep you from overtightening
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
NV241 rear seal leaking GotJeeps TJ Wrangler Technical Forum 1 03-30-2010 02:39 PM
Rear diff seal leaking.. how to fix? ReNxWar TJ Wrangler Technical Forum 3 11-30-2006 07:47 PM
rear main seal leaking sandman'sjeep YJ Wrangler Technical Forum 5 11-25-2005 10:07 AM
Rear seal leaking? Drew99 TJ Wrangler Technical Forum 1 01-11-2004 09:45 AM
rear pinion seal leaking panhd TJ Wrangler Technical Forum 2 04-12-2002 03:41 PM
