Rear port on Valve cover - JeepForum.com
post #1 of 10 Old 07-02-2011, 02:03 PM Thread Starter
kjg26
kjg26's Avatar
The port (right angle piece) coming off the rear of the intake manifold of my 4.0 is all clogged up. looking to replace it and the hard line running from the valve cover to the intake manifold i'm sure is clogged too. Where can i get the angled piece off the valve cover? And does the line to the manifold HAVE to be a hard line? Can it be vacuum hose?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 10 Old 07-02-2011, 02:31 PM
4.7stroker
http://www.rockauto.com/
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 10 Old 07-02-2011, 03:03 PM Thread Starter
kjg26
kjg26's Avatar
great site! Still can't find the part though.
kjg26 is offline
post #4 of 10 Old 07-02-2011, 03:25 PM
4.7stroker
go to
Jeep
1993
Sahara
Emissions
PCV Valve / Crankcase Ventilation Connector
Price $3.14
Dwayne
[url]
[url]
post #5 of 10 Old 07-02-2011, 04:11 PM Thread Starter
kjg26
kjg26's Avatar
Thats the piece for front of valve cover. The one on the rear has a small vacuum passage, very small.
kjg26 is offline
post #6 of 10 Old 07-02-2011, 04:21 PM
MJMPC
I think he wants the little hard plastic line that goes fron the elbow to the manifold.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #7 of 10 Old 07-02-2011, 04:39 PM
4.7stroker
Then I would start with the dealer if it not cleanable or if you can't come up with a work around.
Dwayne
[url]
[url]
post #8 of 10 Old 07-02-2011, 05:19 PM Thread Starter
kjg26
kjg26's Avatar
is there any reason why a soft rubber vacuum line wouldn't work in place of the hard line?
kjg26 is offline
post #9 of 10 Old 07-02-2011, 05:27 PM
stratostix
Follow 4.7stroker's instructions for the elbow fitting. As far as the vacuum line, I got mine from advanced autoparts yesterday (also got a breather hose from there). Here's the pic (sry I don't know how it came out upside down)
Uploaded with ImageShack.us
stratostix is offline
post #10 of 10 Old 07-02-2011, 06:11 PM
mcmud
1983 CJ8
The soft tube would be fine just as long as the I.D. is the same and it is routed so that it avoids excessive heat from the exhaust manifold.
Why not simply clean the fitting and tube?
mcmud is offline
Moving plastic wiring harness loom from rear of valve cover? Jonman03 TJ Wrangler Technical Forum 5 03-16-2012 08:21 PM
Rear Main Seal and Valve Cover Gasket SoonerDad TJ Wrangler Technical Forum 6 01-30-2011 08:35 PM
Rear main or valve cover gasket? TJBart TJ Wrangler Technical Forum 2 03-19-2010 06:27 AM
Leaking oil after change, rear main seal? Valve cover gasket? ZeroGravity YJ Wrangler Technical Forum 9 10-22-2009 05:39 PM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
