Rear Pinion Seal - JeepForum.com
post #1 of 2 Old 01-24-2002, 09:51 PM Thread Starter
YJNotDone
Rear Pinion Seal
My rear pinion seal is leaking a little and I'm thinking of replacing it soon. How hard is this to do and what am I in for.
95YJ, 4" Procomp suspension lift, 33x12.50 pro comp MT's, custom square tube bumpers, custom interior, body lift and disconnects coming soon along with who knows what else.
95, 4" susp. lift, 33x12.50 ProComp M/T's, custom square tube bumpers, , energy bushings, 4.0 HO, everything stock, 1" or 2" body lift and who knows what else coming soon.
YJNotDone is offline
post #2 of 2 Old 01-25-2002, 09:40 AM
osburn
osburn's Avatar
It's fairly easy, but if we're talking about a Dana 35, there's a one time use crush sleeve involved here. You need to replace it then torque to spec. In a pinch, you can just reuse the existing crush sleeve. But I'm talking trail/get home kind of repair. I'm not sure what the torque spec is on the pinion nut of a Dana 35. But don't be surprised if it's over 200 ft lbs. I know my Dana 60s are like 260 ft lbs.
Matt Osburn
Score 1032
osburn is offline
Rear axle seal/ Rear Pinion seal phillies4752 TJ Wrangler Technical Forum 17 02-01-2010 10:05 PM
D44 rear pinion seal vs. NP231 transfer case seal thejafe TJ Wrangler Technical Forum 14 06-14-2009 01:24 PM
Rear pinion seal TMJeep TJ Wrangler Technical Forum 5 05-12-2007 01:57 PM
Where to get rear D44 pinion pinion seal? Lud04X TJ Wrangler Technical Forum 2 02-22-2007 10:36 AM
Rear Pinion Seal RKSchmidt TJ Wrangler Technical Forum 4 10-13-2006 06:45 PM
