Rear Main Seal - JeepForum.com
post #1 of 5 Old 03-22-2002, 09:48 AM Thread Starter
89JEEPNYC
89JEEPNYC's Avatar
Rear Main Seal
Hey my rear main seal is leaking really bad as a matter of fact on my 89Sahara4.2 . Has anyone out there done one? Hard, easy whats the deal. Any help would be great thanks
89JEEPNYC is offline
post #2 of 5 Old 03-22-2002, 10:32 AM
bighair
are you talking about your rear outpu shaft seal.. on yuor rear differential?? if so. no it's not a hard thing to replace..
I just did mine about 3 wks ago.. just make sure you have a 1/2 inch torque wrench.. and an impact wrench(important) otherwise, it'll be very hard to remove the lock nut.. it's usually Jammed in good.. hehe. once the lock nut is off. pull the yolk out.. pop the seal out clean everything thoroughly, then replace the seal with the new one.. and put your yolk back in screw the locknut and tighter it to the torque specs in a Jeep manual.. I can't remember of the top of my head what it was.
Also, while your there, check your yolk.. once the yolk is off, check and see if it's smooth or it has small lines cut into it.
this could also be the problem.
sometimes the seal cuts small grooves into your yolk which can also cause the leak..
hope it helps
Team Mod Squad
We are here to help YOU!
bighair is offline
post #3 of 5 Old 03-22-2002, 10:53 AM Thread Starter
89JEEPNYC
89JEEPNYC's Avatar
I have to do that seal as well . I noticed a little wetness around that seal.
But I meant the Rear Main Seal on the engine.
Thanks though I needed that other info as well.
post #4 of 5 Old 03-22-2002, 11:07 AM
bighair
k, np.. i havent done the rear main seal on the engine compartement yet.. sorry..
Good luck..
Team Mod Squad
bighair is offline
post #5 of 5 Old 03-24-2002, 11:19 AM
Mdwase
I did the rear main on my 89 yj about a year ago and it wasn't too tough. You do have to remove the timing chain cover and oil pan, so you might as well replace the timing chain. The other thing I remember about this repair, is that you can buy a one piece oil pan gasket that is spendy, but is much more reliable than the 2-4 piece felpro. The last thing is you need a small punch to knock out the crustified seal from the block, but be careful not to scratch anything. No need to drop the tranny for this repair if you do it right. Another thing I did was take a wire tool on a hand grinder and did the oil pan leftover gasket and crap on the outside of the oil pan and painted oil pan a light color to see if you have any oil leaks in the future. If you have any other question, contact me. Good luck.
92 Wrangler, Black,1"Body,31x12.50
89 YJ Wrecked Head on, no roll
90 YJ, SOA, 31 Muds, 4.10's, Lockers.
Mdwase is offline
Is this the rear main seal ? pic chaznad TJ Wrangler Technical Forum 29 05-31-2011 06:50 PM
rear main seal Nick88YJ YJ Wrangler Technical Forum 1 02-13-2009 05:08 PM
rear main oil seal UTWeezul TJ Wrangler Technical Forum 2 01-25-2007 02:01 PM
Rear Main Oil Seal mudfun TJ Wrangler Technical Forum 8 07-29-2005 03:54 PM
rear main seal rockhead YJ Wrangler Technical Forum 2 04-07-2005 06:26 PM
