Rear main seal - JeepForum.com
post #1 of 10 Old 07-30-2011, 05:18 PM Thread Starter
jerresredyj
Rear main seal
I've got everything apart and the upper seal doesn't want to move. I'm using a small punch and have tried tapping both sides. Does this sometimes happen or do I need a bigger hammer?
jerresredyj is offline
post #2 of 10 Old 07-30-2011, 06:04 PM
ROWA
ROWA's Avatar
I had the same problem with my seal, make sure you don't damage or score the seal cavity. I used some penetrating oil and tapped on both sides until it broke lose. It took a while, but eventually it slid out. When you install the new seal, be sure to oil it well and install it in the correct direction.
Good luck
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #3 of 10 Old 07-30-2011, 06:18 PM
phil1330
1964 CJ5
Mine was a pain in the @ss to get out as well....I ended loosening the crank bolts and it slid right out.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #4 of 10 Old 08-10-2011, 08:47 PM Thread Starter
jerresredyj
Had to loosen all the mains, seal slid right out. Also replaced the oil pump, timing chain, gears and cover. Took it out last night for about an hour ride and no leaks so far Thanks for the help. Now I need to fix the exhaust leaks.
post #5 of 10 Old 08-10-2011, 09:46 PM
phil1330
1964 CJ5
Nice
phil1330 is offline
post #6 of 10 Old 08-11-2011, 04:13 AM
VACJ5
argh... your thread might have just bumped my rear main seal up on the list of things to do...
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #7 of 10 Old 08-11-2011, 06:41 AM
pasinbuy
Easy job. How clean did you walk away from it?
pasinbuy is offline
post #8 of 10 Old 08-11-2011, 09:47 PM Thread Starter
jerresredyj
CLEAN!!!! I pressure washed top to bottom and still made a mess but not as bad as if I hadn't washed it first.
post #9 of 10 Old 08-12-2011, 07:50 AM
pasinbuy
I drained my oil the night before to let the oil drip down, I have a lift in my garage, and still made one hell of a mess.
Other than the clean up, it was a easy job.
You must loosen three or four main bearing caps to get the top seal out. Just loosen a little and let the crank come down a fraction.
pasinbuy is offline
post #10 of 10 Old 08-12-2011, 10:59 AM
mark8201
1987 YJ Wrangler
I have done a few rear mains some come out easy others not so easy. One thing I wanted to point out, is that if you are hitting it with a punch make sure you are hitting against the metal ring which is molded into the seal. If you are only hitting against the rubber material, it will be difficult to break the seal loose. As others have said you may need to loosen the crank to get the old top half out. Just be patient and take your time.
mark8201 is offline
Rear Main Seal jth0033 YJ Wrangler Technical Forum 18 11-24-2010 12:52 PM
rear main seal monkeyhouse YJ Wrangler Technical Forum 4 09-22-2010 09:35 AM
Rear Main Seal Job Outer Seal? sherwoodiv YJ Wrangler Technical Forum 3 08-15-2010 05:28 PM
Rear main seal, and transmission seal leaking tra4689 TJ Wrangler Technical Forum 11 05-03-2010 10:47 AM
rear main seal diesel158 YJ Wrangler Technical Forum 11 07-02-2006 05:28 AM
