Rear lower shock mount - JeepForum.com
post #1 of 8 Old 08-11-2013, 02:44 PM Thread Starter
MathewWalsh
The rear passenger side lower shock mount went on my YJ. How would I go about fixing this? Do I have to weld it on? I've heard about lower shock mounts that bolt on to the rear axel but I don't know if those are any good or what.
MathewWalsh is offline
post #2 of 8 Old 08-11-2013, 02:47 PM
jokerchief462
It's up to you but I would get a new weld on one and fix it that way my preference.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 8 Old 08-12-2013, 01:47 AM
boatsandhose
Mine has broken before, I have never heard of bolt on ones, just grind off the old one, and weld on the new one. The part was only about 30 bones or so too.
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #4 of 8 Old 08-12-2013, 04:31 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Happens to the best of us
Luck Favours The Prepared
Anticanman is offline
post #5 of 8 Old 08-13-2013, 03:32 PM Thread Starter
MathewWalsh
Hahah thats exactly it.
Should I go with these? http://www.jeep4x4center.com/warrior...ir-war101.html
post #6 of 8 Old 08-13-2013, 03:39 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I solved mine with a 8.8. Ymmv
post #7 of 8 Old 08-13-2013, 04:21 PM Thread Starter
MathewWalsh
I want to do that but its just too far down the list to even consider at the moment.
post #8 of 8 Old 08-13-2013, 06:29 PM
jbolty
jbolty's Avatar
you can weld on new brackets that are higher, then get the MORE shock relocator kit to raise the top higher so as not to loose any travel. That will gain you some clearance on the bottom. The MORE kit will still be used when you get the 8.8 eventually.
jbolty is offline
