Rear Locker for YJ w/3.07 rear - JeepForum.com
post #1 of 7 Old 10-28-2001, 12:38 PM Thread Starter
gosling1
gosling1's Avatar
I am looking for some input about a locker for a 3.07 rear. This is my daily driver with some offroading on the weekend. Am I going to have to change my gearing to get a good locker?
chris
2.5" Lift, no track bar, no sway bars, dual K&N filters, custom exhaust stack, custom front and rear bumpers, welded front and rear
Tango Uniform
gosling1 is offline
post #2 of 7 Old 10-28-2001, 06:44 PM
RodeoRob
RodeoRob's Avatar
No, you gearing doesn't really limit locker choice at all. If you're looking to go as cheap as possible, can't be the Powertrax Lockrights, but they can be a little harsh on the road. Powertrax No-Slip adds more street friendly features but tags about $100 on the price. Both of these can be installed by the average weekend mechanic.
On the expensive side you can go with a selectable locker like and ARB or an OX. These are great because you can turn them on and off, and therefor be uneffected on the street. If you wanna spend the money, they're worth it. But you'll also have to get a shop to install em, as resetting the gears is required.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 7 Old 10-29-2001, 08:41 AM
osburn
osburn's Avatar
Like the rice burner dude says, no ya don't "have to" change gears. But if you select a locker like the Detroit, ARB or Ox, you're gonna have to pay to have the gears setup anyway, so ya might as well upgrade is usually the consensus. And really, I had them 3.07s once too. Going to 4.10s felt like I had finally released the parking break.
If you're not planning on doing gears for awhile, then ya should probably do a lunchbox style locker, realizing it won't last forever. I wouldn't do the full carrier style locker if you're not doing gears yet because when you do change the gears, your locker for the 3.07s won't work with the deeper gearset and you'll be buying another locker.
Matt Osburn
Score 1032
osburn is offline
post #4 of 7 Old 10-29-2001, 08:54 AM
RodeoRob
RodeoRob's Avatar
LOL
-Rob
Robert Gorrell
RodeoRob is offline
post #5 of 7 Old 10-29-2001, 06:09 PM
osburn
osburn's Avatar
I've never referred to you by your nickname since you been here. And been getting progressively worse. 'Bout damn time you acknowledge one.
Matt Osburn
Score 1032
osburn is offline
post #6 of 7 Old 10-29-2001, 09:42 PM
powjunkie
Once again Osburn speaks the good word. Best to do the gear and locker mod at the same time. I was recently in your shoes, trying to decide which locker to go with for the daily driver. I also had the 3.07's. Anyway, since I someday plan to do an axle swap, I opted to not go with the golden ARB's. I'm very happy with my 4.10's and a Detroit Truetrach in the rear. I left the front open after several weeks of contemplation. Someday, when I have another ride to work, I'll be fully locked.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #7 of 7 Old 10-29-2001, 09:55 PM
evilpsych
evilpsych's Avatar
yeah.. go 4.10's when you do the locker(s).. it's what i have planned when i do an ARB setup..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
front locker vs. rear locker Snydermann TJ Wrangler Technical Forum 44 11-28-2009 07:41 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
rear arb locker highrisetj39.5 TJ Wrangler Technical Forum 11 05-25-2007 09:47 AM
Rear locker 4cylYJ YJ Wrangler Technical Forum 4 01-24-2006 09:47 AM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
