Rear light wiring - JeepForum.com
post #1 of 3 Old 05-31-2001, 12:10 PM Thread Starter
jmsjeep
Rear light wiring
Please help!!
I have been trying to run wires for a trailer by splicing into my rear lights. I cannot get everything to work. Running lights, brakes, blinkers. Does anyone know what each of the wires are by color, etc.?
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 3 Old 05-31-2001, 09:55 PM
osburn
osburn's Avatar
I've done this at least 3 times now on YJs, but I'll be damned if I remember what the color codes are. I always tag into the wires on the drivers side of the tub, near the rear most rollbar upright. Right on top of the fender there are all the wires you're looking for. I just use a DC probe with a good point and tie in there.
Matt Osburn
Score 1032
osburn is offline
post #3 of 3 Old 06-03-2001, 07:51 AM
jeeptuff
Get a test light, that's the easiest way.... I can look up the codes for you if you like!!
Eric
Once again Jeepless in Seattle
jeeptuff is offline
Reverse light/rear turn signal wiring csxfbird TJ Wrangler Technical Forum 9 05-21-2010 11:57 AM
fog light indicator light wiring questions. rocknjeep YJ Wrangler Technical Forum 4 12-27-2009 09:16 AM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 07:47 AM
94YJ Rear Brake Light Wiring Diagram PaulGarch94YJ YJ Wrangler Technical Forum 2 01-14-2009 08:12 AM
Wiring LED rear brake light UTWeezul TJ Wrangler Technical Forum 2 03-14-2008 08:17 PM
