Rear light wiring - JeepForum.com
 1Likes
  • 1 Post By DirtKar
post #1 of 13 Old 09-07-2017, 08:45 AM Thread Starter
Jeep43
Rear light wiring
Size:  357.1 KB I wired this light as my back up light but I would like to use it as a work light or convenience light. Any idea how I could wire a switch to it so I don't have to leave the ignition open with the shifter in reverse? Maybe a diode wired inline so I don't get any power going back to the reverse light switch on the transmission.
Jeep43 is offline
post #2 of 13 Old 09-11-2017, 12:33 AM
timatoe
timatoe's Avatar
I suppose you could use a diode, but I don't think it's necessary, there's nothing to backfeed really.
I'd simply run the light off of your reverse switch and then tap a secondary switched power source to the same line.
timatoe is online now
post #3 of 13 Old 09-12-2017, 03:57 PM
NHfireLJ
NHfireLJ's Avatar
This ^^^^
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #4 of 13 Old 09-12-2017, 04:56 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Ya got me thinking about this... it would be fine unless he somehow is using that light and activates the reverse at the same time. At that point he's bucking power and it's going to blow both circuits.
I guess if he brought both sides of the reverse switch up to a toggle that would work, as long as a second circuit is not introduced. Not sure if that's what you meant by secondary.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #5 of 13 Old 09-12-2017, 05:04 PM
NHfireLJ
NHfireLJ's Avatar
Nah, I've wired mine the same way on the jeep and on my fullsize... no issues
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #6 of 13 Old 09-12-2017, 05:04 PM Thread Starter
Jeep43
I'm just gonna wire in a diode. I found an extra one I had from when I wired my existing lights to use when flat towing.
Jeep43 is offline
post #7 of 13 Old 09-12-2017, 05:08 PM
DirtKar
DirtKar's Avatar
You must have been typing while I was adding to my post.
NHfireLJ likes this.
YJOTM JULY 2014
DirtKar is offline
post #8 of 13 Old 09-13-2017, 01:17 AM
timatoe
timatoe's Avatar
The voltage doesn't add to itself from multiple sources, the most you can get to the light is 12v. So, even if the switch is on and you shift to reverse you still can't get more than 12v.
post #9 of 13 Old 09-13-2017, 07:56 AM
Myjeep1986
Rear lighting
Here is what I have as a set up, lights in bumper work off switch or when I put in reverse; Simple install;
Myjeep1986 is offline
post #10 of 13 Old 09-13-2017, 11:02 AM
Fourtrail
1974 CJ6
Simple spdt (single pole double throw) switch On-Off-On. Left from Back up light switch, Center to the light and Right from a constant power source. One position is backup, center is off and the other powers it up as a work light.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #11 of 13 Old 09-13-2017, 03:59 PM
DirtKar
DirtKar's Avatar
This is true, you wouldn't get more than 12v but... two different 12v sources (circuits) contacting each other won't play nice.
YJOTM JULY 2014
DirtKar is offline
post #12 of 13 Old 09-14-2017, 07:37 AM
Fourtrail
1974 CJ6
Why? They both come from the same battery through a switch to the same return ground path. If both are on, the only thing happening is you have effectively increased the wire size.
post #13 of 13 Old 09-14-2017, 12:02 PM
timatoe
timatoe's Avatar
I'm thinking of it like a water spigot, if you have a "Y" fitting at the spigot and run two hoses off of it, then "Y" the two back together later into one hose you're getting the same output whether one or both sides of the first "Y" are on.
