Rear Leaf Main Eye Bushings - JeepForum.com
post #1 of 12 Old 09-14-2010, 06:09 AM Thread Starter
89WhyJ
Got a question regarding the rear leaf spring main eye bushing. Upon installing new shackles, I found out one of my rear leaf springs was missing part (almost half) of the main eye. So, I decided to replace it with a leaf spring from a salvage yard since I didn't have the money to replace all of them. Anyway, I have the energy suspension poly bushing kits for the front and rear end. However, the kit includes larger bushings for (I assume) the main eye. These are two piece bushings with the sleeve. When I went to remove the leaf spring, I found that the main eye has some sort of single piece bushing with a larger inner sleeve. Also, it looks like it has an outer sleeve as well. Do I need to purchase a different bushing for the main eye? I see where quadratec sells one, and it looks like the one I pulled from my spring. It appears to have a thin outer sleeve, bushing, and thicker inner sleeve. Can anyone point me in the right direction here. Thanks!
FWIW...that main eye bushing was a complete PITA to get out. I ended up drilling multiple holes through the rubber and finally twisting the inner sleeve out.
89WhyJ is offline
post #2 of 12 Old 09-14-2010, 06:17 AM
pasinbuy
I am not completely sure what you are talking about without pictures. It sounds like a piece was put in the bushing to make it fit the bolt better or the rubber.
You are good as long as the new bushing fits the bolt and rubber.
pasinbuy is offline
post #3 of 12 Old 09-14-2010, 06:28 AM
fratis
fratis's Avatar
stock springs have a completely different factory bushing system. it uses a inner and outer sleeve. i believe if you remove the outer sleeve the aftermarket poly bushings will fit. measure first as i havent played with stock springs in a very long time.
fratis is offline
post #4 of 12 Old 09-14-2010, 07:00 AM Thread Starter
89WhyJ
I was actually wondering if the poly bushings would fit if I removed that sleeve. I'll give that a shot. If not, I guess I'll have to order the stock eye bushing. Thanks!
89WhyJ is offline
post #5 of 12 Old 09-14-2010, 10:01 AM
mighty4banger
I just did polys in my upper frame eyes... The instructions stated to remove the out metal sleeve if it exists... and the bushings say they will fit frame or spring eyes.
Hope that helps.
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
post #6 of 12 Old 09-15-2010, 07:09 PM Thread Starter
89WhyJ
So, does anyone have good ideas on how to get that outer sleeve out?
89WhyJ is offline
post #7 of 12 Old 09-15-2010, 07:15 PM
Georgec3_
2010 JK Wrangler
Removing the metal sleeve is a pita. There are about 3 ways that I can think of and they all require a bfh and a chisel. I had access to a small oxy/acetyl setup that I was able to cut thru the sleeve then with a cold punch and chisel, pound it out. Second way, try to cut through the sleeve with a cold chisel. Third, score through with a sawzall or hack saw then use the cold chisel between the sleeve and the eye. No matter which way you choose it is a PITA!!!!
Georgec3_ is offline
post #8 of 12 Old 09-15-2010, 07:21 PM
YYJ87
Heat that whole end up w/ a regular torch untill the rubber slides out of the outer sleeve w/ a little pushing ("hot sticky mess" is a good description) then use a hack saw to cut throught the sleve folowed by a screwdriver/chisel to fold that outer sleve in untill it releases from the spring eye. I did 4 of these not to long ago, Easy job.
I think i even have pics.(maybe- ill look later)
yyj
YYJ87 is offline
post #9 of 12 Old 09-15-2010, 09:17 PM
Mark05059
you can use a ball joint press to push the outer sleeve out
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #10 of 12 Old 09-15-2010, 09:37 PM
jeep108
Once you get the rubber out, if your careful you can use a sawzall and cut a small section out of the sleeve, just be careful not to cut into the spring. Then with the tension off the sleeve you can pry, beat or twist what's left of the sleeve out
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #11 of 12 Old 11-13-2010, 04:38 PM
yabo71
Try
I just did this today to 2 front springs. Instead of a torch I used a drill 1/8" and drilled several holes the rubber all the way around. Then drove the center busing out then did the saw cut through the outer bushing and pried it out.. about 30 minutes for 2 of them..
yabo71 is offline
post #12 of 12 Old 11-23-2013, 11:40 PM
Dani1108
Where can I get the stock ones
Dani1108 is offline
Teraflex control arm bushings and rear track bar bushings Robbypfd TJ Wrangler Technical Forum 5 02-15-2011 03:55 PM
Different size Main Eye Bushings 1990 YJ ?? Plyj YJ Wrangler Technical Forum 4 03-06-2010 08:05 PM
Rear leaf spring bushings The Rat YJ Wrangler Technical Forum 13 08-14-2007 07:10 PM
what grease for main eye bushings? 91GTA350 YJ Wrangler Technical Forum 1 11-09-2005 10:27 PM
Leaf spring bushings? ILIAMOJEEP YJ Wrangler Technical Forum 1 10-05-2002 09:28 AM
