rear frame repair - JeepForum.com
post #1 of 4 Old 04-12-2010, 09:05 PM Thread Starter
ssmks
rear frame repair
My new rear frame sections from Daveys Geep came today,They look great like eveyone said they do, BUT what do I do with the shakles now that the rear frame is 1/4" wider that before? Ive searched the site and I cant find any mention of what to do with shackles now that frame is wider? Thanks for the help.
ssmks is offline
post #2 of 4 Old 04-12-2010, 09:17 PM
ritjobbie
First, I had no idea where Bliss was until today. I was trying to figure out why I was getting WLKK east of exit 42 on the Thruway.
I'm not sure what you are _supposed_ to do, but I would think you have two options:
1) build/find shackles that step down from wide to narrow
2) use stock shackles with washers at the spring side
With #1 you might need to find/buy/make 1/2" ID sleeves that are 1/4" longer for the frame side of the shackle.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #3 of 4 Old 04-12-2010, 09:37 PM
hallsofstone
I'm looking at the same frame repair on my 94...passenger side is the only one with that rust hole right thru the frame where the shackles for the leaf springs bolt thru. what do those frame sections cost, where can I find them, and should I do both sides if I have to do one for sure?
Noobs gotta start somewhere, might as well be there...
hallsofstone is offline
post #4 of 4 Old 04-12-2010, 10:09 PM
hallsofstone
NVM...just found the threads on that. Still getting used to JF, was on HCF (honda civic forum) for years. Couldn't pass up this heep!
I need help with frame repair!!! mligeikis YJ Wrangler Technical Forum 75 02-06-2014 12:00 PM
Frame repair justpicaname YJ Wrangler Technical Forum 14 04-24-2010 10:37 PM
rear frame repair help! yjripper YJ Wrangler Technical Forum 3 03-21-2010 09:09 PM
TJ Frame Repair BRLK222 TJ Wrangler Technical Forum 12 06-24-2009 06:09 PM
Rear frame repair justpicaname YJ Wrangler Technical Forum 1 06-23-2009 08:23 AM
