Rear end Swap - JeepForum.com
post #1 of 9 Old 08-31-2011, 02:01 PM Thread Starter
Thumper01
1987 YJ Wrangler
Rear end Swap
I found a Ford 8.8 rear end that I want to but on my '87 wrangler. My question is this. When getting a lift kit for the jeep do I need to get anything different? Are the springs the same? The u-bolts? etc.
Thanks in advance for any help.
Thumper01 is offline
post #2 of 9 Old 08-31-2011, 02:25 PM
TheNewbie
You have to move the spring perches ont he 8.8 so that it is the same as the D35. Then you can use the same springs. As it sits though the 8.8's perches are a slightly different width than the D35.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 9 Old 08-31-2011, 02:28 PM
4.7stroker
The U bolts are also different because the axle tubes are much larger on the 8.8. Any driveline shop can get/make them for you.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 9 Old 08-31-2011, 02:32 PM Thread Starter
Thumper01
1987 YJ Wrangler
I knew spring perches where different. I am getting the rear end kit from M.O.R.E. So if I weld the new spring perches and shock mounts on the only thing different for the lift kit would be the U-bolts?
post #5 of 9 Old 08-31-2011, 02:34 PM
dtn8tr
Which IIRC are 3" instead of 2 9/16".
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #6 of 9 Old 09-01-2011, 04:42 PM Thread Starter
Thumper01
1987 YJ Wrangler
The rear end has disc brakes so how do I deal with that? Do I need a new master cylinder?
post #7 of 9 Old 09-01-2011, 04:57 PM
dtn8tr
The only thing that is an issue is the e-brake...you either have to fab a bracket for it or I think that there is an aftermarket kit for it.
dtn8tr is offline
post #8 of 9 Old 09-01-2011, 04:57 PM
klrstew
I'm in the process of the 8.8 swap right now myself. Here are a few resources I am using for my research. Hope it helps.
http://www.jedi.com/obiwan/jeep/ford88.html
http://www.jeepsunlimited.com/forums...d.php?t=371713
http://www.therangerstation.com/tech_library/Axles.html
http://www.jeepforum.com/forum/f12/f...inally-636291/
http://members.cox.net/rough-riders/...8/ford8_8.html
You will find most of your answers here. GL. I'll see you on the other side, 8.8 side that is.........lol
P.S. ECGS will have everything you need on this page.
http://eastcoastgearsupply.com/c-130...-tjyjxjzj.html
klrstew is offline
post #9 of 9 Old 09-01-2011, 05:15 PM
I8AHUMR
I used the 8.8 e-brake lines. You can cut them to the 35 lengths and use cable stops to make them work. Google Ford 8.8 ebrake in yj and its one of the first links. It's a jeepforum link. Need hose barbs and that's it.
You don't need to do anything new to the hard brake lines. Use the 35's T for the brake lines on the 8.8. Unscrew the vent tube bolt thing from the 35 and it'll screw into the 8.8 vent tube hole along with the brake line T from the 35. I got the kit from nowhere2jeep. Worked great
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
tj 8.8 rear swap 97yellow TJ Wrangler Technical Forum 5 08-11-2010 10:32 AM
Rear End Swap? -- What should I use? stin1985 YJ Wrangler Technical Forum 4 03-04-2010 05:36 AM
Rear end swap scottieboy YJ Wrangler Technical Forum 6 12-23-2008 10:49 PM
Zj/TJ Rear End Swap Vertical Norm TJ Wrangler Technical Forum 22 10-30-2007 12:13 PM
rear end swap Mudweiser YJ Wrangler Technical Forum 7 02-04-2002 08:24 AM
