Rear End Problems? - JeepForum.com
post #1 of 13 Old 11-14-2008, 01:24 PM Thread Starter
01blackws6
Rear End Problems?
Something is also wrong with the rear end In my 94 yj. After about ten mintutes of driving it will start to make a friction created noise in the rear and you can feel a resistance pulling the jeep to a stop. The guy pulled the cover I bought it off of and said there are no visual failurs with the spiders and the ring, He said the jeep did just get new brakes all around and maybe they need adjusted in the back or something. Any ideas?
01blackws6 is offline
post #2 of 13 Old 11-14-2008, 01:43 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Pull out your haynes manual and get to adjusting your rear brakes. They are definatly hanging up it sounds like.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 13 Old 11-15-2008, 04:02 PM Thread Starter
01blackws6
Well I pulled the drums off, I did not noticed anything wrong the wheels spin free. I guess it is time to tear apart the rear.
post #4 of 13 Old 11-15-2008, 06:38 PM
Nebfarmer
Whoa! I agree with the brake thing. A bad master may cause your problem or dirty fluid or air in the system. Check that carefully first.
Nebfarmer is offline
post #5 of 13 Old 11-15-2008, 07:05 PM
MLJeeper
MLJeeper's Avatar
is it pulling to one side or the other?
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #6 of 13 Old 11-15-2008, 07:10 PM Thread Starter
01blackws6
No is sounds like a mess back there though but still drives smooth but resisting . I am going to jack it up again tomorrow and have someone put it in gear and listen back there.
post #7 of 13 Old 11-15-2008, 09:10 PM Thread Starter
01blackws6
Actually I just drove ot around the block again and it sounds like its coming from the transfercase or the transmission area and also it did not make the sound when I turned at all?
post #8 of 13 Old 11-15-2008, 09:12 PM
rustywrangler
Give your Ujoints a once over if you haven't already then.
post #9 of 13 Old 11-15-2008, 09:15 PM Thread Starter
01blackws6
ok I will tomorrow! Will a bad u-join make a grinding noise?
post #10 of 13 Old 11-15-2008, 09:21 PM
Old4X
1990 CJ7
Yes.
Also squeaking, popping, and clunking, but not all at the same time.
Old4X is offline
post #11 of 13 Old 11-15-2008, 09:23 PM Thread Starter
01blackws6
God I hope it is just the u-joints that would be awesome but that would not exlpain the resistance?
post #12 of 13 Old 11-16-2008, 06:15 PM Thread Starter
01blackws6
Did some inspecting today!!??
Well I jacked it up today. The pinion has more play then it seems like its supposed too. The brakes are good nothing hanging up there. The drive shaft u-joints seem ok no play. It seems like I was hearing something in the passenger side axle tube like a bearing or something. I could spin the axles freely with my hand nothing sounded like when I drive it. I am still stumped, I will tear it down tomorrow probably.
post #13 of 13 Old 11-17-2008, 10:54 AM Thread Starter
01blackws6
Any ideas?
1994 YJ 2.5l. RUST BUCKET!
1" daystar BL.
rear end problems ionakana YJ Wrangler Technical Forum 1 06-23-2009 04:10 PM
Clutch or rear end problems need help SWF-Jeeper TJ Wrangler Technical Forum 12 04-10-2007 03:26 PM
Transmission problems or rear end Jerry Reaves YJ Wrangler Technical Forum 2 01-22-2007 07:18 PM
Any problems with the Dana 35 rear? bigV TJ Wrangler Technical Forum 57 11-06-2006 04:27 PM
rear end problems YJ4x4on35'z YJ Wrangler Technical Forum 2 08-29-2003 06:10 AM
