rear end problems - JeepForum.com
post #1 of 3 Old 08-27-2003, 06:37 AM Thread Starter
YJ4x4on35'z
rear end problems
I can't seem to keep my rear u-bolts tight, and with my driving, i've axle wrapped my spring under and sheared all 8 bolts off of my rear ring gear. i got everything ready to go again, but i'm confused about my rear axle shims to angle the differential. the hole in the shims was made for a lot of play to move it forward or backwards and i'm not sure where at on the shim to torque my u-bolts back down. do i want it on the angle of the shim, or on the flat part at the top of the angle? They are 6 degree shims.
-matt
Black Jeep Club Member #1
2.5 w/211,000
94 Jeep YJ (AX-5/Atlas II)
4.56 gears
4" suspension lift/3" body
35X15X15 Boggers
15X10 REAL Beadlocks (Axis X-treme)
Warn rear bumper w/rear tire carrier
ARB air lockers (Front/Rear)
Pacesetter exhaust/Header
ARB snorkel
AGR heavy duty steering box/pump
Flaming River steering shaft
Dual optimas
Mean Green alternator
Warn 9000xi winch
Four Real front bumper w/skid plate & 6 Hellas
2 windshield mount Hellas
"Outta Control Off-Road"
YJ4x4on35'z is offline
post #2 of 3 Old 08-28-2003, 05:57 PM
Jeepzilla
Ya got me on where your shim goes, but in general, with a lift you need to have the nose of the differential carrier pointing above the horizon. Seems like the shim should be placed to accomodate that. Did you do the lift? Do you still have the instructions? Can you go the the manufacturer's website and ask?? The diagrams of stock suspensions do not show a shim, so it must have come with the lift kit.
My factory service manual specifies 90 ft/lb torque to the ubolts.
"Blessed is one who gives without remembering and receives without forgetting." Rabbi Eleazar, 1250 AD
93 YJ project. 4.0L, stick
MJ-7 re-body, Banks header, 2.5 " pipe, low resistence cat, Flowmaster. K&N filter thru a snorkel.
Jeepzilla is offline
post #3 of 3 Old 08-29-2003, 07:10 AM
Mels95YJ
Mels95YJ's Avatar
I would think that you need new shims. The hole on mine was the same size as the center pin, so there's no play in it at all. It would appear to me that no matter how tight you tighten the ubolts, they will eventually move around causing problems. Do I have scientific data to back this up...no. I'm just going by a gut feeling that that shouldn't be like that. I would say get new shims with smaller holes or fatter center pins. Just my $.02
Mel
Jeep with stuff.
Mels95YJ is offline
rear end problems ionakana YJ Wrangler Technical Forum 1 06-23-2009 05:10 PM
Rear End Problems? 01blackws6 YJ Wrangler Technical Forum 12 11-17-2008 11:54 AM
Clutch or rear end problems need help SWF-Jeeper TJ Wrangler Technical Forum 12 04-10-2007 04:26 PM
Transmission problems or rear end Jerry Reaves YJ Wrangler Technical Forum 2 01-22-2007 08:18 PM
rear brake problems wingzero1285 TJ Wrangler Technical Forum 7 02-07-2004 06:23 PM
