rear end problems - JeepForum.com
post #1 of 3 Old 04-07-2011, 08:11 PM Thread Starter
AJM
rear end problems
noticed some vibration in my drive shaft and hear unhealthy noise coming from the rear end . realized there was play in the yoke so i removed the cap and drained out all the fluid only to find pieces of bearings belonging to the pinion inner kit . how would i go about replacing this bearing kit. do i have to remove all my gears from the rear end to gain access to this bearing and what other troubles may i run into in this job . any advice would be appreciated . thanks
AJM is offline
post #2 of 3 Old 04-07-2011, 08:14 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Repair it by swapping in a Ford 8.8 from a '95-'01 Explorer.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 04-07-2011, 08:48 PM
notmyj
Max
Quoted for truth. Inspect the ring and pinion. Chances are it damaged the teeth, rendering them useless. And repair will require a new gear set and proper set up. For that price you could have an 8.8. East Coast Gear Supply sells bolt in 8.8s for a fair price.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
rear end problems ionakana YJ Wrangler Technical Forum 1 06-23-2009 05:10 PM
Rear End Problems? 01blackws6 YJ Wrangler Technical Forum 12 11-17-2008 11:54 AM
Clutch or rear end problems need help SWF-Jeeper TJ Wrangler Technical Forum 12 04-10-2007 04:26 PM
Any problems with the Dana 35 rear? bigV TJ Wrangler Technical Forum 57 11-06-2006 05:27 PM
rear end problems YJ4x4on35'z YJ Wrangler Technical Forum 2 08-29-2003 07:10 AM
