rear end noise - JeepForum.com
post #1 of 5 Old 11-04-2011, 12:17 PM Thread Starter
bulldoglover170
rear end noise
I have a 8.25 rear end that is making a clicking noise while driving. Faster I go faster the clicking noise. Put on jack stand and spun tires by hand no noise, start it up in gear and clicking noise returns. Pulled diff cover and no chipped teeth anywhere. Also u joints are good. Is there something im missing, any other ideas?
bulldoglover170 is offline
post #2 of 5 Old 11-04-2011, 12:20 PM
94chb
remove drums and take a look
94chb is offline
post #3 of 5 Old 11-04-2011, 07:47 PM Thread Starter
bulldoglover170
Come on guys any ideas
post #4 of 5 Old 11-04-2011, 08:34 PM
Nickabis
It may not be the in the axle, possible transfer case or transmission problem. Have you changed the fluid and inspected the old? I had a clicking in my trans but it was only in third gear, I drained the oil and found a tooth. Just a suggestion.
Nickabis is offline
post #5 of 5 Old 11-05-2011, 04:27 PM Thread Starter
bulldoglover170
Checked rear u-joints again while turning driveshaft by hand and found a bad joint. Replaced and no more noise.
Rear End Noise, HELP Jeff328 YJ Wrangler Technical Forum 11 10-01-2011 08:21 PM
rear grinding noise after complete rear rebuild HELP!!! jeepinjames20 YJ Wrangler Technical Forum 7 07-27-2009 10:36 PM
Bad Rear end noise xboardr311 YJ Wrangler Technical Forum 3 11-12-2008 09:49 AM
Rear Noise Therou TJ Wrangler Technical Forum 3 04-13-2006 02:48 AM
rear end noise garin3 YJ Wrangler Technical Forum 10 08-17-2005 07:56 PM
