Rear end is messed up... What to do? - JeepForum.com
post #1 of 15 Old 10-03-2013, 10:16 PM Thread Starter
bkaab
So something happened with the rear axle in my Jeep. It was a Dana 35 with 3.07 gears and it broke a bunch of teeth of the ring gear and spider gears and the carrier has a lot of movement. Wasn't even off roading. I accelerated a little harder then normal and there it went. Can I rebuild it myself easily or does anyone know somewhere in Michigan or Ohio that has used axles for sale? I just want to get the Jeep back on the road before winter so I can move it out of the way. Ive found good used carrier, ring and pinion set just not sure how to go about installing it right so something like this doesn't happen again.
bkaab is offline
post #2 of 15 Old 10-03-2013, 10:24 PM
c5wagner
You're better off finding another axle, craigslist is probably the best place to start searching, or now would be a good time to get a ford 8.8 or D44
1989 Base YJ TBI 350, 4l60, Np231 SYE/6 pin planetary/Wide chain, D30 ARB, 8.8 ARB 4.56
c5wagner is offline
post #3 of 15 Old 10-03-2013, 10:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Eightpointeight
Luck Favours The Prepared
Anticanman is offline
post #4 of 15 Old 10-03-2013, 10:42 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Eightpointeight
This will be the response you should go with.
Use the search feature and read up on the 8.8 Ford axle upgrade.
If you are pressed for time and its your daily driver, get a used D35 off CL and slap it in. THEN start planning the 8.8 sourcing parts and welding.
Why?
Because it is going to happen again. Not if, when.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luuca is offline
post #5 of 15 Old 10-03-2013, 10:43 PM
flea2107
Rebuilding a differential is not the thing to do unless you have the experience or someone to teach you that has the experience. I blew my rear diff up too. Throw that boat anchor away. I found a SCOUT 2 axle from like 1976. It's a Dana44 and I had it rebuilt with an ARB locker and put off set spaces to bring the lug pattern and axle width to match the jeep wheels. The only advantage to the 8.8 is you can get them with disc brakes, but it is a ford product. And while you're at it change that 3.07 to something useful like 4.10 or 4.56 and of course match the front match your new rear.
flea2107 is offline
post #6 of 15 Old 10-03-2013, 10:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Why?
I went through two replacement Dana 35's before I bought my 8.8. Then I bought several more when I found out how valuable they are to a jeeper and worthless they can seem under a wrecked explorer.
post #7 of 15 Old 10-03-2013, 10:55 PM
Luuca
Luuca's Avatar
I'm socking away the green stuff to build my own YJ within the next 18 months. 8.8 is on the build list.
As I said, OP, if time and money don't permit the 8.8 now, start the process now for the next time the turdy-5 craps out.
YJOTM never
Luuca is offline
post #8 of 15 Old 10-03-2013, 10:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Tick tick tick...
post #9 of 15 Old 10-04-2013, 06:43 AM
Que89YJ
Got the answer for you. Call Chris. He will have one and very very reasonable. Tell him I sent you.
He parts out Jeeps and isnt that far away. he is in Armada.
Chris 810-650-3206
Que89YJ is offline
post #10 of 15 Old 10-04-2013, 08:46 AM
lutzke21
8.8
The right answer.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #11 of 15 Old 10-05-2013, 01:10 AM
ashland82391
I agree with all the rest of then but I know how nerve wrecking an axle swap sounds. I'm in Michigan and always on craigslist. There are d35 all over got around 100$.
Seriously though, I spent 200$ on my entire 8.8 swap. Super easy and a great upgrade.
ashland82391 is offline
post #12 of 15 Old 10-05-2013, 03:40 AM
lutzke21
It's really not that daunting a task. There are plenty of us on here that can help with the mental heavy lifting...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #13 of 15 Old 10-05-2013, 09:00 AM
Que89YJ
Call Chris. He backs up his parts. No reason to guess.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #14 of 15 Old 10-06-2013, 06:58 PM Thread Starter
bkaab
Thanks and will do. Right now I just want to get it back on the road. I'll give him a call this week.
Thanks,
Andrew B.
bkaab is offline
post #15 of 15 Old 10-06-2013, 08:13 PM
WakeDoctor
If you are running stock tires I would look for a D35 with 3.07 at the junk yard and make them almost pay me to take it off their hands. If you are running over stock then I would leave the D35 alone and start looking at axle upgrades that fit would fit my time line/budget. If you want more specific responses then fill out your jeep profile.
WakeDoctor is offline
