rear end locks up in forward but not reverse - JeepForum.com
post #1 of 12 Old 09-17-2011, 01:29 PM Thread Starter
iroc_254u
I just finished putting gears in my rearr end. I got it all back together and it will not go forward but it will go backwards. I. Haven't put my yoke on yet because I am waiting got one would not having the yoke on cause it to do this. Everything seem to turn fine till I pit my tires back on snd set it on the ground. Any input would be great
iroc_254u is offline
post #2 of 12 Old 09-17-2011, 01:55 PM
nembudonna
You mean it foreward and backward with the tires off the ground?
nembudonna is offline
post #3 of 12 Old 09-17-2011, 01:57 PM Thread Starter
iroc_254u
Locks up with tires on the ground. Spin freely when it was on the jack stands
post #4 of 12 Old 09-17-2011, 02:27 PM
G30SFF250
Drive backwards!
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #5 of 12 Old 09-17-2011, 02:34 PM
nembudonna
I really can't understand your original post. You mean you heven't put the yoke on yet? Are you just pushing it?
post #6 of 12 Old 09-17-2011, 03:21 PM
sbsg2005
how did you set up the pinion depth with out the yoke on?
sbsg2005 is offline
post #7 of 12 Old 09-17-2011, 03:39 PM Thread Starter
iroc_254u
Got it. I put the yoke on works good now.
post #8 of 12 Old 09-17-2011, 03:44 PM
nembudonna
Glad to hear that.
post #9 of 12 Old 09-17-2011, 07:13 PM
sbsg2005
Still want to know how you set up the gears with out the pinion yoke on.
sbsg2005 is offline
post #10 of 12 Old 09-17-2011, 07:17 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
May be better not to know mate...
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #11 of 12 Old 09-18-2011, 08:39 AM
sbsg2005
Probably is better not to know.
sbsg2005 is offline
post #12 of 12 Old 09-18-2011, 09:47 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Can you say "pinion depth"?
While not funny (well, maybe to some of us ) my guess is that the carrier now has some fresh gouge marks since its not meant to be part of the brake system.
Joe Dillard is offline
30RH A/T issues: no forward or reverse Altairus YJ Wrangler Technical Forum 2 02-12-2013 11:10 AM
32RH goes forward in reverse? viperbluelx TJ Wrangler Technical Forum 5 12-19-2010 08:01 AM
Water Pump: Forward or Reverse Flow? zener6 TJ Wrangler Technical Forum 3 04-02-2009 10:18 PM
Forward or Reverse Axles? PDX_XJ TJ Wrangler Technical Forum 4 07-12-2005 11:31 AM
Axle Movement - forward/reverse DanH YJ Wrangler Technical Forum 3 12-04-2002 03:49 PM
