rear end help!! (yota swap) - JeepForum.com
post #1 of 2 Old 04-04-2002, 02:36 PM Thread Starter
rollinashortysahara
ok jp magazine says a toyota truck axle is a good swap i found one with 4.30 gearing and an electric locker but it also says they need a brake and driveshaft adapters and advanced adapters doesn't have it does any one know where to look ????
rollinashortysahara is offline
post #2 of 2 Old 04-04-2002, 07:41 PM
RodeoRob
RodeoRob's Avatar
They are good axles! by brake adapter do you mean the brake lines? the toy lines are probably metric whereas your jeep lines are american standard. That no biggy, you'll just have to cut one end or the other and reflair. As for the driveshaft, just head to your local driveshaft shop and they should be able to set you up with a ujoint for your driveshaft to hook up to the yota flange.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
Zj/TJ Rear End Swap Vertical Norm TJ Wrangler Technical Forum 22 10-30-2007 12:13 PM
Yota Axles on TJ??? Jakemd98 TJ Wrangler Technical Forum 7 07-20-2007 08:37 PM
Yota guy needs help with jeep NDJeep YJ Wrangler Technical Forum 3 06-22-2007 11:11 PM
yota axles!! UCF YJ'r YJ Wrangler Technical Forum 16 02-05-2007 12:58 PM
What axel to swap to??amc,ford,chevy,yota? Charger5 TJ Wrangler Technical Forum 9 04-25-2005 12:24 PM
