rear end going out? - JeepForum.com
post #1 of 6 Old 10-01-2009, 07:02 AM Thread Starter
whitie_08
rear end going out?
well this isnt exactly regarding my yj, but it is my brother's zj. yes i could go to that forum but it should be the same concept, yj or zj with a d35.
what are some characteristics of a bad rearend?
what if it came with a factory limited slip? would it act up if it were wearing out, or just silently turn in to an open diff?
ive never experienced it so i dont know what it would do, and we are trying to figure out a "clunk" that has happened a couple of times, and seems to be coming from the back side of his jeep.
^^^thats a lie.
whitie_08 is offline
post #2 of 6 Old 10-01-2009, 07:10 AM
theducksguts
I don't have a YJ but it is the same end, and the same concept. A worn Trak-Lock would just simply be open. It uses clutches and if the clutches aren't working it will just run open.
Clunking, grinding, metal on metal sounds, heat. All signs that something is wrong. It doesn't take much to open it up and take a look. Just some new gear oil and some rtv. Put it up on jack stands and chuck the front wheels. Rotate the axle. If the other side rotates the same direction the Limited slip will engage, if it rotates opposite, then it is worn out. You can also inspect the ring gear. It has been a while but I believe Trak-Lock still has spider gears as well.
Pull the cover and take a look.
Check out my
theducksguts is offline
post #3 of 6 Old 10-01-2009, 07:10 AM
zdox11
i would pull the diff cover and inspect the gears. also make sure the braces that keep the diff in are tight and at the recommended torque. you can spin the tires and look for alignment issues with the pinion and the ring.
zdox11 is offline
post #4 of 6 Old 10-01-2009, 08:39 AM
Louie4
Take off the driveshaft at the pinion yoke and spin it by hand, check for play and spin the tires some. If you feel any kinks I would pull the diff cover.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 6 Old 10-01-2009, 08:47 AM
MJMPC
Check your trackbar bushings if you still have one .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #6 of 6 Old 10-01-2009, 09:55 AM Thread Starter
whitie_08
will do it saturday morning
thanks guys.
luckily he doesnt have to drive it that much right now, so it will gice us time to check things out.
^^^thats a lie.
JK Limited Slip rear VS Electronic Locking Rear - Difference? Soft 8 JK Wrangler Technical Forum 28 06-04-2012 05:26 PM
Rear Axle / Rear Tire Clunking After Exiting Expressway czar97 TJ Wrangler Technical Forum 8 12-12-2011 09:18 PM
1987 jeep yj rear disc brakes rear proportioning valve? handyman48066 YJ Wrangler Technical Forum 4 06-06-2009 11:41 AM
Question-rubicon dana 44 rear-4.10 fit standard tj rear dana44 rytrac TJ Wrangler Technical Forum 3 09-04-2005 01:44 AM
Rear trackbar bracket? Drilling? Rear axle shift thebulkinator TJ Wrangler Technical Forum 5 04-03-2005 08:17 AM
