rear end decided to die - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rear end decided to die
2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1990 - 1998 Jeep Cherokee Front Wheel Bearing & Hub AsEngo winches available at www.rockridge4wd.com! Free shipp
Unread 12-01-2008, 06:15 PM   #16
SteveJcoYJ
Originally Posted by jbolty View Post
all explorers and some (very few) rangers, and a handful of explorer sport-trak.
IIRC the cut off for drum vs disk is 1995
would this include mountaineers in the time period ?
most parts are interchangeable explorer to mountaineer
SteveJcoYJ is offline   Reply With Quote
Unread 12-01-2008, 06:51 PM   #17
wildman90
the one from the ranger is too narrow. read the jedi story. your looking for the 8.8 out of an explorer, very common although hard to find the right ratio and limited slip. the stock d35 is 60.5"wms to wms and the 8.8 is 59.5" only 1/2" on each side. no issue unless you run stock rims. again read the jedi story, i found it to be right on the money. in st louis they go for about 200-250.
chuck
p.s. mountaineer is the mercury version of the explorer--same axles
wildman90 is offline   Reply With Quote
