rear drum Brake Adjusting Screw - JeepForum.com
post #1 of 12 Old 10-18-2011, 10:07 PM Thread Starter
bill8bud
Which one goes on the passenger side and which one goes on the drivers side. The big difference between the two is one is a right hand thread the other is a left hand thread. This happens to be in a dana 44 but I am hoping a dana 35 is the same.
I am following this diagram to bad its only the drivers side.
http://www.lunghd.com/Tech_Articles/...ke_Service.htm
Thx
bill8bud is offline
post #2 of 12 Old 10-19-2011, 01:25 AM
NeilBedwin
Are you sure they are different. I did my rears a few months ago and I didn't notice that one had a left hand thread but I did do them one at a time.
I though that one had the screw on the left and one had the screw on the right. Put the adjuster lever in and then it is just a matter of putting the adjuster in so that the gear is in the right place.
If you look further down your link pictures you will see a photo of the adjuster. Seems the screw bit has L or R on it !
NeilBedwin is offline
post #3 of 12 Old 10-19-2011, 09:01 AM
Lemoore-on
I know they have 2 different part numbers for left & right. I just ordered and received the adjuster kits for mine. I can check when I get home from work if they are actually threaded differently.
Is there an "L" or "R" stamped on them like the last diagram shows?
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #4 of 12 Old 10-19-2011, 09:40 AM Thread Starter
bill8bud
the only diffrence I see is one has a left hat hamnded thread and the other is right handed. If you can check when you get home that would be great
bill8bud is offline
post #5 of 12 Old 10-19-2011, 09:54 AM
Que89YJ
Que89YJ is offline
post #6 of 12 Old 10-19-2011, 10:06 AM
kahanabob
they are marked inside on the threaded piece on the end
kahanabob is offline
post #7 of 12 Old 10-19-2011, 10:13 AM
superj
i imagine when you try threading one in, it will or won;t go in. that would be a fairly fast way to tell
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 12 Old 10-19-2011, 10:50 AM Thread Starter
bill8bud
Thank you!!!!!
bill8bud is offline
post #9 of 12 Old 10-19-2011, 10:59 AM
EABiker
I've been doing drum brake jobs for nearly 40 years, and I still like to take a digital pic of the old parts in place before removing them, so I know how they go back!
EABiker is offline
post #10 of 12 Old 10-19-2011, 12:11 PM
kahanabob
agree, also do one side at a time so you can refer to the side that is together. i always get confused when doing drum brakes....
post #11 of 12 Old 10-19-2011, 04:59 PM
Tompatt
1987 YJ Wrangler
yep. just did my first ever brake job on my dad's little danger ranger and had a heck of a time getting parts. I got a left adjuster screw kit instead of a right. sucks.
Thomas
-1987 YJ
Tompatt is offline
post #12 of 12 Old 10-20-2011, 01:25 PM
Lemoore-on
Even the replacement "Duralast" parts are stamped L & R. The left has the backwards threads.
Mike
Rear Drum Brake Help - Tight Drum AFTER new shoes! rastadog TJ Wrangler Technical Forum 31 10-21-2011 05:19 PM
Headlight adjusting nut / screw mlelah YJ Wrangler Technical Forum 7 01-11-2011 10:56 AM
rear drum brake help jaspepp TJ Wrangler Technical Forum 2 04-26-2010 12:30 PM
92 Rear Brake Drum corner40 YJ Wrangler Technical Forum 6 03-20-2005 07:02 AM
Rear brake drum removal Jeff Merkel YJ Wrangler Technical Forum 10 06-30-2002 09:10 PM
