Rear driveshaft U joint question - JeepForum.com
post #1 of 5 Old 02-17-2009, 10:04 AM Thread Starter
caseyjoneswys
1988 YJ. The u joint in the rear drive shaft at the transfer case has no straps for removal/installation. Whats the best way to go about getting it off? Thanks
caseyjoneswys is offline
post #2 of 5 Old 02-17-2009, 10:47 AM
kloppk
Welcome to the forum!
Please fill out your "Profile" so we can help you quicker and with less questions and assumptions.
Assuming your Jeep is "stock" you'll need to remove the 4 bolts holding the two straps that secure your drive shaft to the rear differential.
Once removed lower the end of the drive hsaft down and simply slide it out of the tcase.
You'll need to have a catch pan handy as some tcase oil will leak out. Not much, just some.
You'll now need to remove the 4 "C" clips that secure the front u-joint bearing caps and then remove the bearing caps and bad u-joint.
kloppk is offline
post #3 of 5 Old 02-17-2009, 10:47 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
You have to remove the axle end first and then slide it out of the tcase. They you can use a bench vice or socket with hammer to press the U joints out.
Search for u joint replacment. there are several good writeups.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 5 Old 02-17-2009, 02:27 PM
whitie_08
they may be stubborn, but the caps will come off [eventually]
^^^thats a lie.
whitie_08 is offline
post #5 of 5 Old 08-17-2011, 01:58 PM
caligiuri87
1994 ZJ
im doing this to same story but do i need to mark the shaft that goes into the tc?? or soesnt matter if its rotated and putting in
caligiuri87 is offline
What part number for front and rear driveshaft u joint? wmeyer116 TJ Wrangler Technical Forum 9 09-02-2009 01:09 AM
help with rear driveshaft u joint!!!!!!! incagoldjeep TJ Wrangler Technical Forum 17 08-24-2009 02:03 PM
Rear driveshaft length, joint to joint? Anyone have one to sell? shrewd YJ Wrangler Technical Forum 0 07-06-2009 03:32 PM
U-Joint upgrade for NP231+D35 rear driveshaft Panici TJ Wrangler Technical Forum 14 08-07-2008 04:42 PM
Rear U-Joint in the driveshaft - part cost and labor involved Sparty TJ Wrangler Technical Forum 12 07-09-2007 12:12 PM
