Rear driveshaft issues - JeepForum.com
post #1 of 11 Old 04-28-2013, 10:53 AM Thread Starter
RG_Jeep
I just finished a clutch job (flywheel, clutch plate, pressure plate and release bearing). While I was under there with the drive shafts off, I figured I would be pro-active and replace all the U-Joints.
Problem one, (rear shaft) I pressed in all the new joints fine, then went to bolt the rear shaft to the diff, and the U-joint didn't fill up the space between the clips on the diff yoke. It is as though I needed an asymmetrical U-joint that measures 3 1/4 inches in one direction to fit the drive shaft, and 3 5/8 inches the other way! This really baffled me. Did I hang on the the original joints after pressing them out? No. Upon the advice of one parts person I placed two O-rings between the joint and the cup, making it wider in one direction to fit into the diff yoke. I know this isn't right, but at this point I was anxious to test the new clutch.
Problem two. I went out for a test ride, the clutch worked GREAT! But, when I get up to about 30 mph, I get a bad vibration in the seat of the pants (apparently the drive shaft). uh oh. Did I get it in properly? Did my Jerry-rigging cause it to be out of balance?
Got any clues? I feel as though if I had simply left the shafts alone, I would be merrily driving my Jeep today argh.
RG_Jeep is offline
post #2 of 11 Old 04-28-2013, 10:56 AM Thread Starter
RG_Jeep
Make that a 1993 YJ, I make a mistake on my profile
RG_Jeep is offline
post #3 of 11 Old 04-28-2013, 12:23 PM
Louie4
I know some '94 and '95 models used the 1330 u-joint. It is possible that someone put a later model D35 or yoke on yours. I know there is a u-joint for that application because a lot of guys run into that when they swap in an 8.8. It has a flange that accepts the 1330 but their driveshafts are made for 1310.
Some reference material:
http://www.jeepforum.com/forum/f9/13...t-part-618095/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 11 Old 04-28-2013, 02:09 PM Thread Starter
RG_Jeep
Thanks brother, looks like I'll get a spicer 5-134X ordered
RG_Jeep is offline
post #5 of 11 Old 04-28-2013, 03:23 PM
kahanabob
Guess this falls into the category " if it ain't broke don't fix it"
kahanabob is offline
post #6 of 11 Old 04-28-2013, 04:59 PM
kbson
Sounds similar to the issue I just went through. I ended up replacing the rear yoke.
You can see my thread here
kbson is offline
post #7 of 11 Old 04-29-2013, 11:26 AM
bogleparsons
who ever told you to use 2 extra o-rings, should be added to the list of people you dont take advice from.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #8 of 11 Old 04-29-2013, 12:57 PM
Tarpo
You need a step joint. Almost every auto parts store sells them.
88 yj. 95 4.0 4 Brl carb, Msd ignition, offenhouser intake, headers. Ford 8.8 rear end, sun fire seats. About to install a newer ax 15 to replace my tired ba10.
Tarpo is offline
post #9 of 11 Old 04-29-2013, 01:11 PM
Tarpo
Oops, didn't see this, you should be set..
Tarpo is offline
post #10 of 11 Old 04-30-2013, 01:03 AM
mike_breaker_5
i would have to agree that the o-ring idea should not be in your bag of tricks. i was running an offset u-joint in the rear before the d60's went under. i had a bunged up rear pinion angle and the axle was ready to explode at any second and i barely had any vibes.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #11 of 11 Old 05-01-2013, 11:34 AM Thread Starter
RG_Jeep
Concur on the idiot that recommended the O-rings! I knew it wasn't the thing to do, but was desperate for short-term. I FINALLY found a NAPA store with a parts guy that is smart and he took care of me. I'm roll'n and smile'n.
RG_Jeep is offline
