rear driveshaft - JeepForum.com
post #1 of 6 Old 12-11-2001, 03:29 PM Thread Starter
byj92
rear driveshaft
apparently there's a lot of extra torque placed on the driveshaft when you put 35x12.50's on your YJ...who knew... anyway i had to send my driveshaft to the doctor to be rebuilt cause it flew off and of course the yoke was ate to he11 so i had to get a new one of those too...does anybody have a "how-to" on installing them? the driveshaft seems easy enough seems to just slip into the tranny and then the shaft just gets bolted to the yoke...but i'm not completely sure...and the yoke...NO CLUE ON THAT ONE...and if anybody has any suggestions on how to prevent this...maybe help make things a little more stable to prevent this from happening any time soon...the doctor said that it was a common problem on jeeps with tires 31" and up so i'm sure SOMEBODY else has experienced this...thanks guys
byj92 is offline
post #2 of 6 Old 12-12-2001, 09:44 PM
osburn
osburn's Avatar
There's a big bolt dead center in the yoke. It comes off easiest with an impact wrench. There's a crush sleeve that should be replaced and then the bolt put back on and torqued to spec (I don't know the torque spec off the top of my head). But, I know of several times where the bolt was removed, the yoke replaced and bolted back on till it was "good'n'tight". I'm not saying I recommend it and any other disclaimer that goes along with public advice. But I've done it and not had a problem and have watched others do the same.
Matt Osburn
Score 1032
osburn is offline
post #3 of 6 Old 12-14-2001, 01:11 AM
jeffy
jeffy's Avatar
Well, for crush sleeve's you're supposed to record the torque with a lbs-in torque wrench. Then reproduce that . Shims aren't as crucial, and "Goodntight" works fine if you've done a few. You don't want to overtighten the bearing preload on a Crush sleeve design. From what I remember the sleeve sets the pinion depth and bearing preload.
*** www.4BangerJP.com ***
jeffy is offline
post #4 of 6 Old 12-16-2001, 11:20 PM
IBjeepN4mud
I giggle when I read when someone else has lost a drive shaft. I had a 92 with a slip yoke eliminator and had a small vibration driving at highway speeds. My brother was behind me in his 91 jeep cruzing at 65mph.
While talking on cb I asked if he felt a vibration maybe due to the road. Then I heard a loud pop bang and was loosing power. The rear view showed my drive shaft in 2 pieces tumbling down the road. Thanks to the SYE I picked up my shaft and locked into 4wd and drove home off the front wheels. My point is if you have a lift you need a CV joint drive shaft to help correct the steep angle that gives you the vibration.
1st jeep 83 cj8 scrambler
2nd jeep 92 yj wrangler
3rd jeep 88 yj wrangler
4th jeep ??????????? Still looking
IBjeepN4mud is offline
post #5 of 6 Old 12-24-2001, 07:33 AM
Nightshift
The only way i now to get away with drive shaft is:slip yoke eliminator and cv joint
It may be expensive but it worth it.
88YJ(NIGHTSHIFT)
258 C.I./Trans.Trimac 176/TC NP208
Dana 44 Front&Rear (Full size wide)
37-12.5-15 Super swamper SSR on
15x8 6 stud Jimmy rim
Next mod:Gear&Locker/360 AMC engine
2002 LIBERTY LTD (FREEDOM)
Nightshift is offline
post #6 of 6 Old 12-24-2001, 10:27 AM
geepYJ95
This might sound like a stupid question...but what does a Slip Yoke Eliminator (SYE) and a CV joint do exactly??
Green Jeep Club Member #14
'95 YJ Sahara Edition, green w/ tan hard and soft tops, Flowmaster 40 series, New cat, 2 10"eclipse subs, pioneer cd deck, and Xtant A series 6001 amp.
geepYJ95 is offline
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 08:53 PM
rear driveshaft curlyfry123 TJ Wrangler Technical Forum 2 10-05-2009 06:00 PM
Rear Driveshaft doublelfj YJ Wrangler Technical Forum 1 06-24-2009 12:27 AM
Rear driveshaft change when changing rear axles? skifast1 TJ Wrangler Technical Forum 7 12-23-2004 09:36 AM
