Rear Driveshaft - Page 2 - JeepForum.com
post #16 of 25 Old 01-02-2012, 05:31 PM
DEERSLAYER94YJ
Originally Posted by Almost a jeep View Post
I've been watching videos and everyone is right, they make it look pretty simple, but it always does on someone else's video. I'm sure everyone has their own opinions but is there a reason to go with one certain kit over another brand? Ebay has a couple that are pretty inexpensive.
I went with rugged ridge a few years back and all is still well. Was a fairly easy job however, I do suggest taking the T-case out of your jeep and installing the SYE on a work bench. Only issue I remember having was removing and installing the snap rings, your def. gonna want that tool. Then once your all done, blue or black RTV, and tighten all your bolts to spec.
Nightcrew Member #093
DEER--- It's whats for supper!!
DEERSLAYER94YJ is offline
post #17 of 25 Old 01-02-2012, 05:59 PM
mazyj
I agree with the just save your money until you can do it right argument, but if its really bothering you until then either buy or make a transfer case drop.
http://www.quadratec.com/products/16006_100.htm
Honestly you can make one from a couple dollars of steel, a few longer bolts, and a drill.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #18 of 25 Old 01-02-2012, 06:05 PM
DEERSLAYER94YJ
good call with the T-case drop, cheap and easy fix for angle reduction
post #19 of 25 Old 01-02-2012, 06:38 PM Thread Starter
Almost a jeep
Good point on the transfer case drop, kind of forgot about the simple fixes.
Surprisingly, my wife just said "If you need it, get it". Well of course I need it.
94 Wrangler SE, 4.0, Auto, SYE, Hard top, 31X10.5X15, 3" Skyjacker, 8.8 w/ disc brakes. 06 Grand Cherokee stock.
Almost a jeep is offline
post #20 of 25 Old 01-02-2012, 10:52 PM
dodger889
Doing the install is easy. I did it never taken one part. Just followed instructions. And yes it is as easy as the videos show. I found one back a few years ago it was 199 and delivered for about 10. If you shop around you can get one for about that price or a little less. I would watch out for the ones that really drop below the 175 or less. Just make sure you get the spline count.
If you just do a TC drop 1/2 washers stacked even will do a good job for a drop.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #21 of 25 Old 01-11-2012, 04:06 PM Thread Starter
Almost a jeep
Well, after everyone's advice and sweet talking my wife, I recieved and installed my SYE with the case still in. Not a horrible job to do. Waiting for my cv driveshaft to come and trying to get ahead of the game. Is there any way to determine which shims I need, prior to getting my new shaft? By my way of thinking, if I measure my pinion flange (8.8) angle, than run a straight edge from the center of the axle housing to the transfer case output shaft, measure that angle than subtract the two, shouldn't that be my shim degree? Now, please point out the flaws in my plan. As always, thanks for the advice.
post #22 of 25 Old 01-11-2012, 04:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If you have the 8.8 you should reweld the perches instead of using shims.
Luck Favours The Prepared
Anticanman is offline
post #23 of 25 Old 01-11-2012, 04:42 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I agree. I used shims when I did my SYE when I still had my 35. They creak and pop like crazy. I was releived when I did my 8.8 and welded the perches correctly.
Randonexplosion is offline
post #24 of 25 Old 01-12-2012, 05:38 AM Thread Starter
Almost a jeep
Agreed, re-welding is the best option but I've used shims and never had a problem with them before and it would sure be a lot easier and faster. Again, is my theory even close to right to determine angle?
post #25 of 25 Old 01-20-2012, 09:47 PM Thread Starter
Almost a jeep
Finally all done! SYE and CV driveshaft all installed and took it for its first test drive tonight in the snow storm we're having. All looks and feels good. After having concerns about the difficulty of installing the SYE, I would encourage anyone with some mechanical skills, to do this themselves. Also, for what it's worth, bought my driveshaft and SYE from www.adamsdriveshaft.com and couldn't be happier with their service and prices. Spoke with the owner on the phone and he was very helpful. Even got a free tshirt. Just wanted to throw that out there for another option on driveshafts.
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 08:53 PM
Use a TJ front driveshaft for rear driveshaft?? JeSimmers TJ Wrangler Technical Forum 4 01-30-2013 03:45 PM
Questions about shortening a Cherokee front driveshaft to make a rear CV driveshaft AnonymousD YJ Wrangler Technical Forum 19 04-19-2011 10:10 PM
rear driveshaft chutta TJ Wrangler Technical Forum 1 04-21-2007 05:44 PM
Rear driveshaft change when changing rear axles? skifast1 TJ Wrangler Technical Forum 7 12-23-2004 09:36 AM
