rear drive shaft problems - JeepForum.com
post #1 of 6 Old 11-28-2010, 01:51 PM Thread Starter
91YJ-98TJ
my jeep now vibrates real bad when i am going at a slow speeds and i have noticed that my rear drive shaft has a lot of play with it. so today i put new u joints in hoping it would fix it but theres still a bunch of play in the front of the drive shaft. so what do you guys think is the problem and how would you suggest me fixing it???
91YJ-98TJ is offline
post #2 of 6 Old 11-28-2010, 01:53 PM
AnonymousD
Do you have a t-case drop?
AnonymousD is offline
post #3 of 6 Old 11-28-2010, 01:59 PM Thread Starter
91YJ-98TJ
yea i dropped it when i lifted it. Its got a 4 inch suspension lift and i did all of this about about 2 years ago and i havent had a problem until now
post #4 of 6 Old 11-28-2010, 02:58 PM
gearhead1985
worn out slip yoke imho i would have to look it over to tell
i have a stock ds if your inerested that is good pm me if you want it or if you want an extra set of eyes look it over let me know i am in pensacola fl for now
i want to put a pic here but the computer won't let me so here is the link
gearhead1985 is offline
post #5 of 6 Old 11-28-2010, 06:06 PM
linusb
If you grab the DS at the slip yoke...is that where the play is? I was just under my jeep today and noticed I have a little bit of play there too. No vibes yet...but am waiting for the day.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #6 of 6 Old 11-29-2010, 08:38 AM Thread Starter
91YJ-98TJ
yea thats where its at
drive shaft
XJ front Drive Shaft for a TJ Rear Drive Shaft after SYE srlbotanical TJ Wrangler Technical Forum 23 02-08-2012 06:26 PM
Drive shaft problems with lift? Caribic-TJ JK Wrangler Technical Forum 5 11-11-2010 08:40 AM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
drive shaft problems help!! muddyfun YJ Wrangler Technical Forum 8 11-28-2008 12:27 PM
POLL: Ok to Drive w/ rear drive shaft? Libtekguy TJ Wrangler Technical Forum 14 07-02-2008 11:25 AM
