Rear Drive Shaft Problem - JeepForum.com
post #1 of 6 Old 06-16-2013, 11:59 PM Thread Starter
Razorback23
Hey guys, I'm replacing the u-joint on my rear drive shaft. I've got both clips off the drive shaft but can seem to get the shaft out. You just push toward the transmission and the pull it back out once the back end falls out, right? Mine wont budge at all. Also, do I need to drain the transmission before taking the shaft out. Won't it start leaking once the drive shaft comes out of the transmission. Thanks for your help guys and sorry if these questions are a stupid, but I need help. Thanks again!
Razorback23 is offline
post #2 of 6 Old 06-17-2013, 03:29 AM
boatsandhose
The last time I pulled mine out I just un did the yoke straps on the diff side and it slid right out. Thought that was normal? Of course it has suffered some stress due to grenading u joints.
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #3 of 6 Old 06-17-2013, 03:54 AM
mike_breaker_5
If your drive shaft is attached to your transmission you have problems. As far as i know there were never any 2wd yj's.
Your DS should be on a slip yoke on the transfer case if it is original. Did someone put a sye kit on the x-case maybe?
is there a slip yoke in the middle of your driveshaft?
does the transfer case side have a double u-joint instead of a single one?
and ... no you do not need to drain the transfer case to change the shaft.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #4 of 6 Old 06-17-2013, 05:35 AM
Rproject
1987 YJ Wrangler
You will lose "some" fluid when you pull the drive shaft, but not a ton. Just have a pan under it so you don't have a mess to clean up.
Assuming no one has installed a slip yoke eliminator kit, yes, the drive shaft should slip forward into the transfer case then be able to be pulled straight back and out. With that said, if the drive shaft hasn't been removed for a very long time, it might be a little stuck at the rear axle. The first time I pulled mine, I had to put a large flat screw driver behind the u-joint and give it a little help to unseat.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 6 Old 06-17-2013, 10:01 AM Thread Starter
Razorback23
Thanks man! I used a screwdriver like you said and it came right out! I did lose some fluid though. Do I just need to put some back in it?
post #6 of 6 Old 06-17-2013, 10:02 AM
Rproject
1987 YJ Wrangler
Not a problem. Glad to help. Yes, refill what you lost. Remove the upper nut, fill to where you can just fell it inside the hole with your finger.
1996 White ZJ
Rproject is offline
drive shaft , removal , u joint
