rear drive shaft - JeepForum.com
post #1 of 5 Old 11-17-2009, 07:38 PM Thread Starter
bigred94
rear drive shaft
hey im doing a 4.0 swap in a 94 yj i have the 2.5 with the ax5 i have the complete 4.0 drivetrain with the ax15 outa 92 yj i was wonderig about driveshaft lenghts for the 2.5 to the 4.0
bigred94 is offline
post #2 of 5 Old 11-17-2009, 09:15 PM
gearhead1985
the 2.5 rear is an 1" longer
i want to put a pic here but the computer won't let me so here is the link
gearhead1985 is offline
post #3 of 5 Old 11-17-2009, 09:28 PM
jerseyrider1119
I have a stock one if you need it pm me
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
I only read the pictures!
95 Rio Grande- 4" Pro Comp lift, 235x75r15 on stock Alloys, Boomerangs, Piolet Trail Lights, Hurc'd, No Sways or Trac, Custom Under Dash Wiring Harness
jerseyrider1119 is offline
post #4 of 5 Old 11-17-2009, 10:33 PM Thread Starter
bigred94
ok i also did the 8.8 swap in it and have 5and half inch suspesion lift so think it would be bad to run the 2.5 one or i could just move the motor mount up the frame rails?
bigred94 is offline
post #5 of 5 Old 11-17-2009, 10:54 PM
gearhead1985
with that much lift you will most likely need a sye and new drive shaft
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 04:33 PM
POLL: Ok to Drive w/ rear drive shaft? Libtekguy TJ Wrangler Technical Forum 14 07-02-2008 12:25 PM
Rear drive shaft ludinator TJ Wrangler Technical Forum 4 04-18-2007 01:24 PM
Can I drive without my rear shaft? TomC TJ Wrangler Technical Forum 12 09-13-2004 09:31 AM
Rear Drive shaft Enjoi Jeepin YJ Wrangler Technical Forum 1 05-19-2003 01:18 AM
