Rear Door Hinges - JeepForum.com
post #1 of 3 Old 04-12-2007, 02:27 PM Thread Starter
JAM56
Rear Door Hinges
Does anyone know if you can adjust the rear door hinges on a 92 YJ. I have an awful rattle that is driving me crazy. I know that I am going to have noise, but it sounds like the door is going to come off. When I open the door, you can see it sag off the frame. I just need to tighten the hinges somehow?
JAM56 is offline
post #2 of 3 Old 04-12-2007, 02:57 PM
Cannon
Cannon's Avatar
I'd first look at the tailgate assembly's bracket & reinforcement, see if their out of alignment.
I'd second look at the latch & striker assembly. The striker itself has plate, shim, and washer. Your shim may be gone. Plus check the striker cover (housing) for loosening.
Final 'guess. The pair of tailgate hinges are one piece design. You could shim the space between the hinge and the tailgate with something, then retighten the torx.
'90YJ Hard & Soft w/Full Drs; 4.2 Rebuild w/ Webber, 30x10.5; Interstate MegatronII D34; Mods: Rock Guards; Hi Lift Inst; Herc'd Tub, Front & Under; Elev Rear Seat; Scty CntrConsole/ Overhead&Rear Boxes; KC Lights-Fr & Rear; PA Sys; Gauges; Int Lts; Batt/Alt Cable; Heater Mods; 8K Winch, KargoMaster Rack w/Yak Megawarrior Basket; Ground Lights (4);Dumped - Optima Yellow after only 4yrs
Cannon is offline
post #3 of 3 Old 04-12-2007, 04:59 PM
JeepN95YJ
I drilled out the hinges on mine and replaced the pin with a 1/2 inch bolt.
JeepN95YJ is offline
Cosmetic fixes? door hinges rusty and hard top window hinges peeled............... hangwire TJ Wrangler Technical Forum 8 08-25-2009 02:39 PM
Chipping Rear door hinges on 4 door jk kramer8 JK Wrangler Technical Forum 13 01-01-2009 09:11 AM
door hinges Axl Jack YJ Wrangler Technical Forum 7 05-11-2007 07:21 PM
Door Hinges graynat2 TJ Wrangler Technical Forum 1 01-24-2007 11:00 AM
