Rear disc brakes for a 87-90 D35 - JeepForum.com
post #1 of 2 Old 10-19-2007, 12:40 PM Thread Starter
JohnRodriguez
Ok guys, heres a interesting piece of info for all you who arn't big fans of the kit that stainless steel braks co. offers for the the 87-90 wranglers. the wilwood disc brace kit #140-7143, which is for the ford 9" small bearing housing, will bolt up directly to the D35 axle with no modifications. the only thing you will have to do is make sure that the rims that you have will clear the rotors. Tha backing plate is the same bolt patten and the wilwood kit has 2.66" of offset and the D35 has 2.64 measured on my axle housings. The willwood kit comes with a retaining plate shaped like a "C" and it is the only piece that is not used, you will use the original ones on the axles.
I had currie build me a ford 8" housing for my 89 wrangler and if all the measuring that I did on my 35 were not correct, then it would have not been a loss since I could have put the 8" right in.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #2 of 2 Old 10-19-2007, 02:03 PM
dukegnarley
i hope you mean 8.8" as the 8" can't really take that much power.
Unlimited Length YJ "Sasquatch"
Renix 4.0
AW4 swap with
= DONE
dukegnarley is offline
Rear Disc Brakes TimBrown TJ Wrangler Technical Forum 15 10-01-2011 11:38 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
1987 jeep yj rear disc brakes rear proportioning valve? handyman48066 YJ Wrangler Technical Forum 4 06-06-2009 11:41 AM
Rear disc brakes on a tj? BobA TJ Wrangler Technical Forum 11 06-02-2009 09:04 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
