rear disc brake parking brake cables - JeepForum.com
post #1 of 3 Old 09-09-2013, 09:49 AM Thread Starter
mopartec
i have collected all the parts for doing a rear disc brake conversion. im using Grand Cherokee parts. what parking brake cables do i use or is there an adpater piece out there
mopartec is offline
post #2 of 3 Old 09-09-2013, 10:32 AM
SeanB95YJ
for that, I'd use the GC cables.
haven't done it myself so I don't know if the front of the cables will hook directly to your equalizer.... but that's what I would try first, at least to look at.
take one of your YJ cables to an auto parts store and compare it to a GC cable.... you already know the brake side will work, just compare the other ends to see if they're the same (or close enough)
Good luck.... and please fill out your profile (before someone else asks you a little less nicely LOL )
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 3 Old 09-09-2013, 10:40 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by seanb95yj View Post
for that, i'd use the gc cables.
Haven't done it myself so i don't know if the front of the cables will hook directly to your equalizer.... But that's what i would try first, at least to look at.
Take one of your yj cables to an auto parts store and compare it to a gc cable.... You already know the brake side will work, just compare the other ends to see if they're the same (or close enough)
good luck.... And please fill out your profile (before someone else asks you a little less nicely lol )
Luck Favours The Prepared
Anticanman is offline
