Rear Differential??? - JeepForum.com
post #1 of 3 Old 12-27-2001, 03:42 PM Thread Starter
Cottun
just bought a 93 4.0 a couple months ago. notice the rear differential had a little fluid on it. a few thousand miles later it is completely covered in fluid. should i be concerned? thanks for any help.
Cottun is offline
post #2 of 3 Old 12-27-2001, 04:17 PM
glm 87 wrangler
First check and see were the fluid is comming
from.Make sure its not engine oil or tranny fluid blowing back on it.If thats not the case hurry and replace the dif.seal or were ever its comming from because low fluid in there will cause you major problems.I would put a rush on this.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 3 Old 12-30-2001, 07:17 PM
JACKED
I completly agree dont waste anytime, if its definatly coming from ur diff take 2 seconds and change seal. it will save alot of money in the long run.
93 YJ 4.0L 5 speed. 3" body and 4" suspension lift. 35x12.5 MT tires.
JACKED is offline
Rear Differential claygarland YJ Wrangler Technical Forum 40 09-19-2009 09:18 AM
99 TJ Rear Differential holyearth TJ Wrangler Technical Forum 21 09-07-2008 12:46 PM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 12:38 PM
Rear Differential ? mknherhappy TJ Wrangler Technical Forum 2 08-02-2006 12:20 PM
Rear Differential jeepinarkansas YJ Wrangler Technical Forum 4 03-01-2002 06:43 AM
