Rear Differential - JeepForum.com
post #1 of 5 Old 02-28-2002, 06:18 PM Thread Starter
jeepinarkansas
1982 CJ8
Rear Differential
How do I know if my rear diff is limited-slip, and if it is does it need some additive plus the oil?
Thanks
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #2 of 5 Old 02-28-2002, 06:32 PM
bobznew
First of all, it would help to know a little bit more about your vehicle. You might want to create a signature profile. Year, model, engine, tires, mods, etc. would all be very useful.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #3 of 5 Old 02-28-2002, 07:23 PM Thread Starter
jeepinarkansas
1982 CJ8
sorry...maybe this will help
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
post #4 of 5 Old 02-28-2002, 08:52 PM
bobznew
Don't take me as the foremost authority on the matter, but I think that the rear diff on '95 YJ's was open. I could be wrong though; you should wait for someone else's word...
Sorry I couldn't be any more help.
bobznew is offline
post #5 of 5 Old 03-01-2002, 06:43 AM
Don Tibbetts
I don't know about your 95 but if I recall correctly when I bought my 93 it was a factory option. Mine didn't have it and it would spin all the power out one wheel without the slightest hesitation.
In any case, I would recommend using a synthetic lube in the diff. I know if you use Amsoil AGR or TGR it will not only offer better performance than a conventional lube but you don't have to use the friction modifier. If you use a conventional lube, you will have to add a friction modifier or LSD additive.
Don Tibbetts
Don Tibbetts is offline
Rear Differential claygarland YJ Wrangler Technical Forum 40 09-19-2009 09:18 AM
rear differential jacobfudgepops YJ Wrangler Technical Forum 6 01-29-2009 08:45 PM
99 TJ Rear Differential holyearth TJ Wrangler Technical Forum 21 09-07-2008 12:46 PM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 12:38 PM
Rear Differential ? mknherhappy TJ Wrangler Technical Forum 2 08-02-2006 12:20 PM
